peter lena 9,731 #1 Posted August 12, 2020 while looking for an erratic starting issue , i found a corrosive dust in wiring, was going to rewire 5 point connector at ignition switch, connector was trashed. found out its an OREGON PART , # 33 - 350 , 5 WAY MULTIPLE CONNECTOR , FOR IGNITION SWITCHES , MADE IN USA ! $ 7.00 , DELIVERED. got it from www. PITTAUTO.COM. ALSO PICKED UP THE TAB INSERT WIRE CONNECTORS , that bind fit into connector , for easy plug on to switch. do that tomorrow, pete 3 Share this post Link to post Share on other sites
rick 270 #2 Posted August 13, 2020 A lot of those connectors that fit into a plastic block should be crimped with an open barrel crimp tool. It is kind of an obscure tool unless one does this work professionally. When I went to work in the radio/equipment install shop for the State Police in 2008 no one had heard of them. I had been doing installs at home for local agencies since 1978. Yes, you can do it with needle nose pliers and get by, like just setting Kohler points to .020 and putting the cover back on, but it's not the correct method. YMMV. 2 Share this post Link to post Share on other sites
RJ Hamner 1,029 #3 Posted August 13, 2020 They are “Packard 56” connectors. I buy them for Del City Electronics they also have the tools needed to remove the wiring from the connector and the metal fittings that go with the connector also the correct insert for the crimp tool. just my .02 2 Share this post Link to post Share on other sites
peter lena 9,731 #4 Posted August 13, 2020 good feed back on that , those PACKARD 56 CONNECTORS , helps to complete the NAMES of parts needed to do this , making this a good reference point for others doing a similar project , also a BARREL CRIMP TOOL, ADDRESS thanks , pete Share this post Link to post Share on other sites
