Ed Fox 20 #1 Posted August 12, 2020 Hello, me again in need of more help. I also noticed that on one of the front tires of my 314 the wheel bearings are going bad. Is this a special bearing that has to be purchased through a Toro parts supplier or can someone provide me with the bearing number? Thank you! Kindest regards Ed Share this post Link to post Share on other sites
JCM 10,250 #2 Posted August 12, 2020 Ed, I just bought 12 from Toro, between 12 and 14 dollars. Part # 110513. Been using them for years and never a problem. Good luck Jim 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,522 #3 Posted August 12, 2020 There are two types bearings available now. One type has a single seal and can be greased with a gun after installation. The second type has 2 seals and can not be greased. If greasing is attempted the pressure will not enter the bearing and the bearing gets pushed out of the hub. The best way to prevent that is to replace the grease fitting in the hub with a screw. Garry Share this post Link to post Share on other sites
953 nut 60,353 #4 Posted August 12, 2020 I have used these sealed bearings and am very pleased with them.Set of four for under $ 15.00 delivered to your door. https://www.ebay.com/itm/4-WHEEL-BEARINGS-TORO-WHEEL-HORSE-11-0513-25-1210-110513-and-251-3-4-x-1-3-8/281473149545 3 Share this post Link to post Share on other sites
pacer 3,177 #5 Posted August 12, 2020 I decided yrs ago to replace these bearings with the sealed ones --- having to pump tons of grease into the inside of the hub hoping some of it would get to the bearing just didnt make sense to me, besides the mess of it!. My main mower D200 has had them for some 6-8 yrs and are still going, cutting some 1 1/2 acres every summer. 1 Share this post Link to post Share on other sites
