Larry P. 45 #1 Posted August 10, 2020 Hello. I need some direction on wiring the big rectifier/regulator on my C160 with the K341 motor. This is the big rectifier with the three spades. Two spades above and one spade under (L shaped pattern). I know the orange wire goes to the B+ spade, but does it matter which wires from the stator go to the AC+ and AC-. Any help would be greatly appreciated. Thanks, Larry Share this post Link to post Share on other sites
ebinmaine 80,087 #2 Posted August 10, 2020 Does not matter sir. AC connector. Alternating Current is just that. Alternating. You can put either one to either place and you'll be fine. 4 Share this post Link to post Share on other sites
Larry P. 45 #3 Posted August 10, 2020 Eric. Thank you so much for your reply. Have a wonderful day. 1 Share this post Link to post Share on other sites
