dhabicht1 0 #1 Posted May 12, 2009 does anyone know the correct procedure to adjust the hydro linkage/brake linkage for this tractor? I have adjusted the brake band according to the manual fully compressed bring then back off 1/2 turn but now when I step on the brake it wants to creep in reverse. Share this post Link to post Share on other sites
Just Piddling 0 #2 Posted May 13, 2009 Since no one has responded, I'll take a stab at it. When you engage the brakes, the travel control is locked in neutral. There is a neutral adjustment under the seat in the form of a cam bolt. Jack up the rear, loosen lock bolt and slowly adjust cam. You may also have to adjust the linkage from the lever to the plate on the hydro. Do a search for "adjust 520-H" and see what comes up. I know the subject has been discussed several times. Remember to set the search date range to "any date". Good Luck Share this post Link to post Share on other sites
dhabicht1 0 #3 Posted May 13, 2009 thanks Chris your a lifesaver Share this post Link to post Share on other sites
04fxdwgi 0 #4 Posted May 17, 2009 does anyone know the correct procedure to adjust the hydro linkage/brake linkage for this tractor? I have adjusted the brake band according to the manual fully compressed bring then back off 1/2 turn but now when I step on the brake it wants to creep in reverse. I have the Eaton manual for the 1100 if you want it. Has everything in it. Let me know your e-mail and I'll send it to you. Bill Curtis Share this post Link to post Share on other sites
dhabicht1 0 #5 Posted May 17, 2009 I would love to have it, do you need to snail mail or is it in electronic format? Share this post Link to post Share on other sites
kpinnc 14,603 #6 Posted May 17, 2009 Your manual is available for download at Toro.com. The adjustment procedure is in it. Kevin Share this post Link to post Share on other sites
04fxdwgi 0 #7 Posted May 19, 2009 I would love to have it, do you need to snail mail or is it in electronic format? Just need an e-mail address and I'll send it electronically Share this post Link to post Share on other sites
tomshorse4keeps 7 #8 Posted April 26, 2016 On 5/17/2009 at 5:58 AM, 04fxdwgi said: I have the Eaton manual for the 1100 if you want it. Has everything in it. Let me know your e-mail and I'll send it to you. Bill Curtis Hello Mr. Bill Curtis, I just joined the forum and saw your post on 5/17/2009 regarding adjusting the transmission in a 520H, mine is a 1997, if the Eaton manual you have applies to my 520H, I would appreciate it if you could send it to me. Mine doesn't have reverse, it just kept getting more and more hard, to engage reverse, until it stopped going in reverse at all. My e-mail is trspot1969@gmail.com Thanks in advance, Tom Share this post Link to post Share on other sites
WNYPCRepair 1,923 #9 Posted April 26, 2016 14 minutes ago, tomshorse4keeps said: Hello Mr. Bill Curtis, I just joined the forum and saw your post on 5/17/2009 regarding adjusting the transmission in a 520H, mine is a 1997, if the Eaton manual you have applies to my 520H, I would appreciate it if you could send it to me. Mine doesn't have reverse, it just kept getting more and more hard, to engage reverse, until it stopped going in reverse at all. My e-mail is trspot1969@gmail.com Thanks in advance, Tom As a quick test, lift the brake with your left foot while shifting into reverse. If it works easily with the brake lifted, your brake return spring is broken, disconnected, or missing entirely. Also check the cam plate. Watch how it operates when you shift and see if something is binding Share this post Link to post Share on other sites
tomshorse4keeps 7 #10 Posted April 26, 2016 37 minutes ago, WNYPCRepair said: As a quick test, lift the brake with your left foot while shifting into reverse. If it works easily with the brake lifted, your brake return spring is broken, disconnected, or missing entirely. Also check the cam plate. Watch how it operates when you shift and see if something is binding Hi Brian, Thanks for the reply, something is definitely binding, the rod doesn't travel all the way, into the cam plate "slot", it gets stuck, in the middle, I am trying to figure out what needs to be adjusted, I saw some other posts, where others tried to adjust "something" and lost the forward gear or the brake, I don't want to make it worse! Others said to jack up back wheels and then adjust while it's running Mine has a seat switch, it won't run unless your seated. obviously you can't adjust anything while your seated on it, I don't know how to bypass the switch. Tom Share this post Link to post Share on other sites
WNYPCRepair 1,923 #11 Posted April 26, 2016 Did you try lifting the brake pedal? If the brake isn't returning to fully lifted, you can't shift. I had the same problem until I accidentally figured that out. popped a spring on the brake and it worked perfectly Share this post Link to post Share on other sites
cleat 7,249 #12 Posted April 26, 2016 Make sure there is no grass or other debris that could be jamming up the cam. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,454 #13 Posted April 26, 2016 If the pto is OFF the engine should run without being in the seat. Garry Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #14 Posted May 2, 2016 Years ago my shift linkage turn buckle rod ends behind the dash broke and it wouldn't "shift" so I would pull all the access panels off at the dash and tunnel and check all the rod ends and linkages ,plus I replaced the ball style rod end with a "tie rod" style end but the picture I attached shows my new to me 520 and the shift linkage under the column, Jeff. Share this post Link to post Share on other sites
