vmen84 61 #1 Posted July 25, 2020 I need instruction on how to change the oil in a 1974B 100 B 100 wheel horse I can't find my manual to see what kind of oil it takes or what kind of oil filter to use. I've also been looking on YouTube for videos on how to do this any help would be appreciated. I was also wondering do I need to change the oil for the for the gear fluid it's underneath the seat? I may have pronounce that wrong if so could somebody tell me what that is? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,737 #2 Posted July 25, 2020 This folder has a section from the lube charts for your tractor. The second picture lists the models with a code as to what your model uses. The third picture uses the code for the products required. They may differ from the owner manual but are the latest recommendation. Click on this picture to get to the others Illustrated parts list Most users recommend a Wix 51410 or Napa 1410 hydro filter. For hydro oil look to see what color oil is in it now. If it is red use ATF (Automatic Transmission Fluid) and if it is amber use motor oil. Others can comment on the best oil types for your climate. If in doubt ask questions. Garry 1 Share this post Link to post Share on other sites
vmen84 61 #3 Posted March 3, 2021 I was reading the manual and under lubrication my code is C1. Then it says multi purpose lithium-based I'm assuming that's for greasing the gears but what kind of grease ? I'm also not exactly sure what I'm greasing? Share this post Link to post Share on other sites
