MIbudgetbowhunter53 0 #1 Posted July 24, 2020 I am new to the Forum and have been doing a bit of digging through the attachment PDF. I recently purchased a C-145 Auto I am looking to add a couple of attachments to it. I am looking at adding a snow blade and have found a couple but have confused myself looking at the cross reference sheet. For instance I found a model # 76-42bc01 snow blade according to that it is a 76-77 model year part number. The owner of the blade says it was on a c-81 which would be a 78-79 model year with a snow blade part number of 96-42bc01. My c-145 would require a 06-42bc01. From the looks of it the blade should work my confusion is the two initial number is 76 the model year produced and 42bc01 being the actual attachment? I appreciate the time and I apologize if this is a dead horse. Share this post Link to post Share on other sites
oldredrider 2,554 #2 Posted July 24, 2020 Any blade with the "bc" in the model # will fit. "BC" designates the B and C models. Your C-145 is a "C" model. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #3 Posted July 24, 2020 Here is a list of the blades in the order they were produced. At that point in time the first digit of the model number was the model year but that did not last long. The C is the key as they fit the C-Series. 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) 1984-1989 model 06-48BC01 (They are now 48" wide) 1990 model 06-48BC02 (Last blade to have 3 angle positions) 1991-1993 model 06-48BC03 (First blade to have 5 angle positions) 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) Garry 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #4 Posted July 24, 2020 Here is a page explaining the model numbers at the time. Click on the picture to view it. Garry 1 Share this post Link to post Share on other sites
MIbudgetbowhunter53 0 #5 Posted July 26, 2020 Thank you for the replies. It is awesome the information that is available on these. I have a Smplicity 3310v and there is hardly nothing out there like this that I have found. Thank You Nate Share this post Link to post Share on other sites
