David414 311 #26 Posted July 22, 2020 Yes. Ignition on, engine off, headlights worked. Why do you ask? Share this post Link to post Share on other sites
pfrederi 19,808 #27 Posted July 22, 2020 2 hours ago, David414 said: Yes. Ignition on, engine off, headlights worked. Why do you ask? Then you have a real charging system. The cheap 3 amp system used on some 414-8 ran the headlights off an AC stator that only worked with engine running. it only charged the battery at 3 amps.... Share this post Link to post Share on other sites
David414 311 #28 Posted July 22, 2020 Good to know, thanks! Share this post Link to post Share on other sites
