TC10284 121 #1 Posted July 20, 2020 Does anyone know if this scrape blade will attach to my 312-A? The scrape blade came with an older 520H I bought a couple years ago. I got the 312-A a few months ago. Pics: https://photos.app.goo.gl/7K79Qa4g7gwL3qTQ6 Share this post Link to post Share on other sites
Stormin 9,988 #2 Posted July 20, 2020 I would think so. But you will need the rear attachamatic for the rear axle. 1 Share this post Link to post Share on other sites
TC10284 121 #3 Posted July 20, 2020 (edited) 6 minutes ago, Stormin said: I would think so. But you will need the rear attachamatic for the rear axle. This? https://www.ebay.com/itm/Wheel-Horse-Original-Rear-Attach-a-Matic/184369745238?hash=item2aed4b0d56:g:EdYAAOSwZehfFKT0 I have one of those (or maybe two) on another tractor and never was sure what they were. Probably the same 520H the blade came with. Edited July 20, 2020 by TC10284 Share this post Link to post Share on other sites
Stormin 9,988 #4 Posted July 20, 2020 That's the one. 1 Share this post Link to post Share on other sites
TC10284 121 #5 Posted July 20, 2020 (edited) 2 minutes ago, Stormin said: That's the one. Thanks! Do I need the rest of the attachments (black parts) on the 312-A to mount it or is that not necessary? Edited July 20, 2020 by TC10284 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #6 Posted July 20, 2020 That blade will fit the 520-H with a straight front axle and a 520-H with the swept forward front axle if you add the extension kit to the blade A-frame. Garry 1 Share this post Link to post Share on other sites
Stormin 9,988 #7 Posted July 20, 2020 (edited) Don't know what those black part are for. Something a PO has made. In the centre of the frame is a plate that you attach a chain or flat bar to the lift arm. There's a hole just behind the deck peg on the lift arm. You need the lever and connections to the blade to angle it. Take a look in the manuals section. Edited July 20, 2020 by Stormin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #8 Posted July 20, 2020 Click on the fuzzy picture Garry 1 Share this post Link to post Share on other sites
stevasaurus 23,857 #9 Posted July 20, 2020 You need to remove those black parts and the red one. That needs to be clear so you have space to lift the blade. 2 Share this post Link to post Share on other sites
Ed Kennell 47,609 #10 Posted July 20, 2020 Just a word of caution. Your 312A with manual lift has the weaker Eaton 700 transmission that is best used as a lawn mower. Your 520H has the stronger Eaton 1100 transmission that is better suited for ground engagement implements. Share this post Link to post Share on other sites
