Countdown To Christmas!
sc halfback
Dirt plowing
sc halfback
I have two 417 A with auto trans.Has any one every plowed a garden with this transmission.Any experience would be appreciated.Are the transmission as good as some members say.  Thank you.  Al
kasey54
Personally I haven't.. however I'd bet you'd be hard pressed to find a better tool for that job.
The eaten 1100 is up to the job, and the hydraulic lift would make it fun. The Kohler engine
is more than up to the job.
  Id say go for it. You will likely want wheel weights to help get the pulling power to the plow.
lynnmor
Tighten the set screws on the rear hubs before you pull hard, it might save you from expensive repairs later.
