John2189 542 #1 Posted July 18, 2020 Anyone know the cr or national seal numbers for the 42” sickle mower? Or are they just o rings? john Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,488 #2 Posted July 18, 2020 WH 1232 is a SKF/CR 9815 WH 1482 is a SKF/CR 12330 http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm Garry Share this post Link to post Share on other sites
John2189 542 #3 Posted July 18, 2020 3 minutes ago, gwest_ca said: WH 1232 is a SKF/CR 9815 WH 1482 is a SKF/CR 12330 http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm Garry Thanks. Garry Share this post Link to post Share on other sites
John2189 542 #4 Posted July 18, 2020 Are there any adjustments in the gearbox to take out play? Are three new parts available? the pulley has about 1/4 play and the bar has 1” play where it connects Share this post Link to post Share on other sites
jeremi3210 742 #5 Posted July 18, 2020 It's all bronze bushings inside the box. They are standard sizes and easy to find. I rebuilt mine a few years back took almost all the sloppiness out of it. Share this post Link to post Share on other sites
John2189 542 #6 Posted July 18, 2020 Ok the hole in the bar is sloppy is or was there a bushing there? Share this post Link to post Share on other sites
jeremi3210 742 #7 Posted July 19, 2020 I put one in mine not sure if it's meant to be there but it worked. Share this post Link to post Share on other sites
John2189 542 #8 Posted July 19, 2020 1 hour ago, jeremi3210 said: I put one in mine not sure if it's meant to be there but it worked. The hole is oblong. I’d have to drill it to fit a bushing Share this post Link to post Share on other sites
jeremi3210 742 #9 Posted July 19, 2020 13 hours ago, John2189 said: The hole is oblong. I’d have to drill it to fit a bushing Mine was also. I filed it it so it was round and just big enough to put the bushing in. The bushing needs to fit kinda snug so it doesn't break. Share this post Link to post Share on other sites
John2189 542 #10 Posted July 19, 2020 25 minutes ago, jeremi3210 said: Mine was also. I filed it it so it was round and just big enough to put the bushing in. The bushing needs to fit kinda snug so it doesn't break. Ok do you remember what size bushing? Share this post Link to post Share on other sites
