RedTomato56 9 #1 Posted July 18, 2020 Where is the trans mission drain plug on 1276 automatic? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,800 #2 Posted July 18, 2020 Item #52 in this illustration. Near the left rear corner of the left case. Left and right always from the operator's position in the seat. It is a socket type that requires an Allen wrench. Hex hole may be full of dirt. Clean it out and tap the wrench in to make sure it is well seated. Thread sealer should be used on the pipe plug when it goes back in. Does not need to be singing tight. https://www.partstree.com/models/1276-toro-lawn-tractor-1966/5054-transmission-0/ Garry 1 Share this post Link to post Share on other sites
RedTomato56 9 #3 Posted July 18, 2020 I saw that it is really mashed up thanks was hoping that wasnt it. Share this post Link to post Share on other sites
stevasaurus 23,506 #4 Posted July 18, 2020 If you can grab it with a channel locks or with an easy out, it should come out without too much trouble. Try giving it a sharp rap with a 2lb ball peen hammer first. ACE, TSC and others carry the plug. 1 Share this post Link to post Share on other sites
