71_Bronco 1,073 #1 Posted July 17, 2020 Just curious if anybody has rebuilt a tractor with all stainless hardware. Is this a good or a bad idea? I know stainless is more prone to galling, but maybe there is a way to prevent this that I don't know about? Maybe something like anti-seize? Thoughts? 2 Share this post Link to post Share on other sites
roadapples 6,987 #2 Posted July 17, 2020 I've used some stainless. Always use anti-seize... 2 Share this post Link to post Share on other sites
daveoman1966 3,884 #3 Posted July 17, 2020 Years ago, I replaced all the mower deck bolts with SS...except for the 12 spindle mounting bolts. The 5 bolts on the lower edge of the dozer blade are stainless too. Share this post Link to post Share on other sites
SylvanLakeWH 32,778 #4 Posted July 17, 2020 I used stainless on the wear bar for my front blade. Salt etc. had done a number on the old bolts... So far so good. Share this post Link to post Share on other sites
WHX?? 58,324 #5 Posted July 17, 2020 Every nut and bolt on these tractors is stainless. Most of my snow blowers and a few decks sport all stainless. I've done a few motorcycles out of all stainless too so my stainless fetish goes way back. No problem with galling. It seldom happens on small diameter bolts. Generally 3/8 diameter and up is where you can run into problems. To prevent it yes antisieze or any lubricant will do. Heat/friction is what causes it so more common on nyloc nuts. Assemble slowly to avoid. Many of @Achto's tractor are done with stainless. 4 2 Share this post Link to post Share on other sites
squonk 48,288 #6 Posted July 17, 2020 I had a guy come into the store years ago and wanted stainless cotter pins. I told him we don't stock them but could get them He left fuming. Said something about "sallies" on the way out the door. 1 Share this post Link to post Share on other sites
JAinVA 4,638 #7 Posted July 17, 2020 I use 1/4" stainless screws and 5/16" bolts on all my WHs.Getting ready to order 5/16" SS carraige bolts for the foot pads. 1 Share this post Link to post Share on other sites
peter lena 10,103 #8 Posted July 17, 2020 JAinVA , your local h/w store probably has s/s carriage bolts in the pull out drawer section , my true value store has a lot of stainless bolts . i have used s/s bolts all over my horse , without any issues ,and nyloc nuts also , pete 2 1 Share this post Link to post Share on other sites
Achto 32,891 #9 Posted July 17, 2020 3 hours ago, 71_Bronco said: I know stainless is more prone to galling, but maybe there is a way to prevent this that I don't know about? Maybe something like anti-seize? I use stainless on every tractor that I redo. To avoid galling I try not to put a stainless nut on a stainless bolt or vise versa. Which ever will be showing gets stainless. Anti-seize and believe it or not Loctite will both prevent galling. I use a fair amount of blue Loctite when I am assembling a tractor. I have yet to have an issue using these practices. 5 5 Share this post Link to post Share on other sites
edgro 680 #10 Posted July 20, 2020 Menards has a good selection of stainless. I tend to use blue or red locktite with no problems. If it needs to come apart, a little heat will release the red stuff 2 Share this post Link to post Share on other sites
tom2p 2,396 #11 Posted July 21, 2020 stainless nuts and bolts without anti-seize should be better than rusted nuts and bolts - correct ? have a small dump cart that has sat for around 20 years outside ... unfortunately ... very poor condition ... some of the fasteners (bolts / nuts) had been replaced with stainless fasteners - they are the only thing on the cart that looks good 4 1 Share this post Link to post Share on other sites
rmaynard 17,634 #12 Posted July 22, 2020 I've used all stainless on several rebuilds. No never-seize, no problem. Only problem with stainless is that it is darned expensive. Found my best deal at BoltDepot.com. You can order as few as one bolt or nut at a time. Share this post Link to post Share on other sites
Skipper 1,792 #13 Posted July 23, 2020 There are different sorts of stainless too. For offshore use, you would use A2 / AISI 316 or better. That stuff can sit on the bottom of the ocean for a 1000 years, and still look exactly the same. Perhaps the Galling is partially due to lesser quality stainless, actually "corroding" a bit, and the fact that it is much harder, so it sets harder too. It wont go soft and loosen up like a normal rustoway bolt does when you apply some brute force. I use a lot of stainless, and has never had any issues. I only use the good stuff though........... 1 Share this post Link to post Share on other sites
squonk 48,288 #14 Posted July 23, 2020 I managed to gall and lock up a couple of 5/8" stainless bolts once on a pump. They weren't tight yet either and no room to cut them off. Had to snap them off with a helper bar. Share this post Link to post Share on other sites
