tallen4392 71 #1 Posted July 15, 2020 Has anyone ever put hydro lift on there machine I have a charger 12 auto and was going to get rid of it for one with hydro lift does anyone know if it can be done and how much work it involves thanks Share this post Link to post Share on other sites
Stepney 2,357 #2 Posted July 15, 2020 The Hydro lift was optional on the Charger and standard on the Electro. For obvious matters you'd need the valve, hoses, bracket to hold the valve, the right rock shaft, and the piston. On the transmission pump there are supposed to be a valve or two as I remember.. actually have been dismantling one for another RS member to add a lift on his 1970 model. Share this post Link to post Share on other sites
ebinmaine 76,199 #3 Posted July 15, 2020 5 hours ago, Stepney said: have been dismantling one for another RS member to add a lift on his 1970 model That'd be me. I'll be doing the changeover sometime this summer... Share this post Link to post Share on other sites
953 nut 63,393 #4 Posted July 15, 2020 If you can find a good parts donor tractor that has the lift and a Sundstrand transmission it can be done. Before you dive into this be forewarned that the rock-shaft can be a problem to remove because the two pieces tend to be brown-welded (rusted) together and the hydraulic cylinder also can be a challenge to remove. Share this post Link to post Share on other sites
Old Guy 2 #5 Posted July 29, 2020 Just done one need to change 2 valves in the trany its easy to find a valve control bought a after market implement cylinder at a farm supply welded the shaft myself if your pretty handy its easy but not cheap by the time you buy everything 1 Share this post Link to post Share on other sites
