Slimpickins 61 #1 Posted July 11, 2020 (edited) So I have a 1973 16 auto that the electric clutch that finely bit the dust and from all my reading here there is not a replacement for the 1in 1/8 crank dia. So I found a c 161 with a manual cluch and was wondering if all the parts would interchange ? I will need more than clutch to interchange . Thank you for taking the time to read . Edited July 12, 2020 by Slimpickins Miss spelling 1 Share this post Link to post Share on other sites
ebinmaine 77,358 #2 Posted July 11, 2020 Have you researched rebuilding/rewinding your own or finding a replacement from someone like Lincoln at A to Z tractor in PA? Share this post Link to post Share on other sites
Slimpickins 61 #3 Posted July 12, 2020 Eric thanks but they are out of stock acording to the website . Share this post Link to post Share on other sites
ebinmaine 77,358 #4 Posted July 12, 2020 1 hour ago, Slimpickins said: Eric thanks but they are out of stock acording to the website . Might want to give Lincoln a call. He's super busy and may or may not keep up the website. Share this post Link to post Share on other sites
oliver2-44 11,214 #5 Posted July 12, 2020 If you tractor has a Kohler you should be able to swap to the manual clutch. If it has anothe rengine, it probable does not have a bearing that will withstand the side load of a manual clutch. Share this post Link to post Share on other sites
Slimpickins 61 #6 Posted July 12, 2020 Yes I do have a k341 on my auto . Maybe this is in the wrong section what I'm looking to find out if the rest of the chase will interchange.I do know the deck plow will work. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #7 Posted July 12, 2020 I think the manual pto clutch should work also. The electric clutch switch also controls the engine START circuit. On the manual pto clutch models a switch is activated by the pto linkage to control the starter. Garry Share this post Link to post Share on other sites
Slimpickins 61 #8 Posted July 12, 2020 Thank you Garry . I will be picking up the c161 today so hopefully all the other parts are interchangeable so I can built one good tractor. Share this post Link to post Share on other sites
