snowhound 106 #1 Posted July 9, 2020 I need to change the brake shaft seal on an Eaton 1100 I assume, and I know assuming is a dangerous thing to do, I need to drain some oil out of the transmission before I change the seal. Am I correct? Share this post Link to post Share on other sites
lynnmor 7,800 #2 Posted July 9, 2020 Check where the oil level is with the dipstick. I believe you will be OK without draining. Jacking up that side will help as well. 3 Share this post Link to post Share on other sites
953 nut 59,787 #3 Posted July 9, 2020 Oil level shouldn't be that high and you will need to jack it up anyway. Be sure to file off any rust and other nicks on the axle and tape off the keyway when you install the seal. 1 Share this post Link to post Share on other sites
snowhound 106 #4 Posted July 12, 2020 Thanks for the replies, now all I need is a cooler day to work on it. Share this post Link to post Share on other sites
