dmyers 5 #1 Posted July 8, 2020 My 520H is over charging at 17 volts and around 14 volts with the headlights on. The battery is newer and I swapped out the regulator from another 520H that is works properly. The regulator that came off the over changing tractor works fine on my other tractor. I hope one of you can suggest something I missed to help me get it running again. 1 Share this post Link to post Share on other sites
953 nut 63,986 #2 Posted July 8, 2020 Generally you will find that overcharging is due to a poor ground on the regulator. Clean up the contacts and mounting points on the old regulator and it probably will work fine. 3 Share this post Link to post Share on other sites
dmyers 5 #3 Posted July 9, 2020 I much appreciate the tip I’ll try it tomorrow. 1 Share this post Link to post Share on other sites
JoeM 9,580 #4 Posted July 9, 2020 6 hours ago, 953 nut said: poor ground on the regulator Plus, If you are relying on the volt meter on the machine, double check with another meter. I always use a hand held meter to check against the one on the machine. 2 Share this post Link to post Share on other sites
dmyers 5 #5 Posted July 9, 2020 Thanks for your input I did use a handheld meter and I was surprised how accurate the tractors meter was. 3 Share this post Link to post Share on other sites
dmyers 5 #6 Posted July 12, 2020 I think the over charging issue will be my ignition switch. I have no continuity between the B plug and the R plug when the switch is in the ON position. I'll find out for sure once I get a new switch. Thank everyone who responded. Share this post Link to post Share on other sites
lynnmor 8,582 #7 Posted July 12, 2020 The voltage should be correct at the center terminal of the voltage regulator, nothing downstream will increase the voltage. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,986 #8 Posted July 13, 2020 23 hours ago, dmyers said: I think the over charging issue will be my ignition switch. I have no continuity between the B plug and the R plug when the switch is in the ON position. I'll find out for sure once I get a new switch. Thank everyone who responded. Don't know what model year your 520 is but most do not use the R terminal on the ignition switch. No wire to it. Garry Share this post Link to post Share on other sites
dmyers 5 #9 Posted July 13, 2020 I did see until after your comment that the wiring diagram shows the R terminal isn’t used, so even though it didn’t test out it doesn’t matter Because it’s not used. I appreciate all suggestions. Share this post Link to post Share on other sites
