David Ullman 142 #1 Posted July 6, 2020 Here's a quick hitch I made. 20200704_134740_Trim_Trim_Trim.mp4 8 4 Share this post Link to post Share on other sites
edgro 680 #2 Posted July 6, 2020 Nice work, good idea well done Share this post Link to post Share on other sites
stevasaurus 23,861 #3 Posted July 6, 2020 That is really slick. I like the spring lock. Share this post Link to post Share on other sites
bottjernat1 2,197 #4 Posted July 6, 2020 Sweet Ill take 2 Share this post Link to post Share on other sites
Tractorhead 9,218 #6 Posted July 6, 2020 Good solution, like it 👍 Share this post Link to post Share on other sites
tom2p 2,396 #7 Posted July 7, 2020 Nice ! I'm in also ! Share this post Link to post Share on other sites
71_Bronco 1,073 #8 Posted July 7, 2020 Looks like a neat idea. Just not sure how strong the draw-bars are on these. Maybe some experts can weigh in here. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #9 Posted July 7, 2020 6 minutes ago, 71_Bronco said: Looks like a neat idea. Just not sure how strong the draw-bars are on these. Maybe some experts can weigh in here. I have done some really heavy towing/dragging (near 1000 lbs) with my 520 and no adverse affects yet bought it new and have used it as a tractor since. Share this post Link to post Share on other sites
David Ullman 142 #10 Posted July 7, 2020 I have used it to move my trailer around with a tractor on the trailer, it is a load but it did the job. Share this post Link to post Share on other sites
lynnmor 9,064 #11 Posted July 7, 2020 (edited) I had a ball mounted on the drawbar and bent it right down with a heavier than average popup camper. I made a ball mount that pins to the drawbar and also links to the upper transmission bolt. With this setup, I have the ball higher and as far forward as possible. The popup is long gone, but the hitch will handle a 6-1/2' x 12' trailer piled high with mulch. In the photo you will see that the support is in two pieces pinned together. I just drop a pin in the drawbar and pin the support. The upper part stays on the tractor. Edited July 7, 2020 by lynnmor 1 1 Share this post Link to post Share on other sites
David Ullman 142 #12 Posted July 7, 2020 I made one of those myself, they work good, but I'm just thinking outside the box I guess. Share this post Link to post Share on other sites
David Ullman 142 #13 Posted July 7, 2020 The other thing I did was drilled and tapped the front of the draw bar, then used a bolt to take up the play. With a small plate between the draw bar and transmission to distribute the weight. 1 Share this post Link to post Share on other sites
