JoeM 10,101 #1 Posted July 3, 2020 Changing out / upgrading an xi ignition and three of the four coil mounting bolts would not budge. The spud was flexing and was close to stripping out. I used this old timers trick from my mining past when we had socket head bolts that were tough to get out. Of course there the bolts were rather large and we used a sledge hammer not a small ball peen. Apply tension with the ratchet and giver a few taps on the butt! Just another way to help stuck bolts out. 12 3 1 Share this post Link to post Share on other sites
pacer 3,180 #2 Posted July 3, 2020 Yep, thats a goodun, I discovered that a few yrs back trying to get a steering wheel off, finally getting POed enough to take my frustration out by a WHAP on the ratchet head and ..... AH-HAH! Since that I often use the trick on several other applications -- for instance, getting the flywheel to POP! off. 2 1 1 Share this post Link to post Share on other sites
CCW 1,509 #3 Posted July 3, 2020 (edited) This goes back to the manual impact driver I had. Put a socket on it and when you struck it with a hammer its internal cam would force a turn at the same time. Use this often on my cars during my college years. Still have it in a box in the shop. Edited July 3, 2020 by CCW 3 Share this post Link to post Share on other sites
Pullstart 70,772 #4 Posted July 8, 2020 On 7/3/2020 at 3:50 PM, CCW said: This goes back to the manual impact driver I had. Put a socket on it and when you struck it with a hammer its internal cam would force a turn at the same time. Use this often on my cars during my college years. Still have it in a box in the shop. yep, I’ve got a nice one of those, very often used too! 1 Share this post Link to post Share on other sites
953 nut 67,502 #5 Posted July 8, 2020 Works well when pulling hubs or a pulley too. Tap on the end of the puller while it is under tension and the shock gets things moving. Share this post Link to post Share on other sites
Tuneup 1,459 #6 Posted July 14, 2020 ... and those impact screwdrivers. I don't know how I lived with just a hammer impact or socket slap until I got one of these. 700lbs of force - she's snapped concrete screws. Driving 3" screws without any pilot holes. Too much fun. That said, the old school methods have served us all well over the years. They'll one day be forgotten so it's grand that there are forums like this to keep them in practice and memory. 3 Share this post Link to post Share on other sites
Mickwhitt 5,259 #7 Posted July 14, 2020 I used an old plumbers trick tother day. Pipe was not quite drained of water and would not solder properly. So I wadded up a slice of bread and jammed it in the pipe, holding back the water. Soldered the joint then flushed the dissolved bread out. Saved memory a time that one Mick 4 Share this post Link to post Share on other sites
CCW 1,509 #8 Posted July 14, 2020 5 hours ago, Mickwhitt said: I used an old plumbers trick tother day. Pipe was not quite drained of water and would not solder properly. So I wadded up a slice of bread and jammed it in the pipe, holding back the water. Soldered the joint then flushed the dissolved bread out. Saved memory a time that one Mick Have been doing my own plumbing for years. Wish I knew this trick these past forty years. 1 Share this post Link to post Share on other sites
EricF 589 #9 Posted July 16, 2020 Yup, a little percussion while putting steady (but not necessarily too much) pressure on the handle works nicely to free up stuck fasteners. Same reason why an an air impact wrench is gentler than just torqueing it off with a long-handled wrench. The impact breaks up rust in the threads and frees everything up better than torque alone. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #10 Posted July 18, 2020 On recently purchased items heading into the refrigerator loosen the lids beforehand, makes opening relish and pickle jars so much easier, when you need them most. Share this post Link to post Share on other sites
Redneckdavis 308 #11 Posted July 23, 2020 On 7/16/2020 at 7:15 PM, EricF said: Yup, a little percussion while putting steady (but not necessarily too much) pressure on the handle works nicely to free up stuck fasteners. Same reason why an an air impact wrench is gentler than just torqueing it off with a long-handled wrench. The impact breaks up rust in the threads and frees everything up better than torque alone. Tightening bolts up before loosening them works too. You'd be surprised Share this post Link to post Share on other sites
