Filippo Meozzi 1 #1 Posted July 2, 2020 I don't know much about my tractor or mechanics in general, bought it a few years ago to mow the lawn and blow snow around the property. We decided to replace the tires and get some that are a bit wider but the clearance isn't enough (were replacing the rear tires). I was looking for hub extensions around 1 1/2 inches but I don't know where to start. does anyone have any input into where or what i need to be looking for? my model of tractor is the 310-8 if that helps and the wheels i have at the moment have 5 bolts to connect to the hub. any help is appreciated Share this post Link to post Share on other sites
ebinmaine 77,324 #2 Posted July 2, 2020 I have two inch thick aluminum spacers on my Cinnamon Horse. Also had to buy special lug nuts to fit inside the holes in the spacer. I think I've got maybe $65 in the whole thing? I can get you the links for what I bought later on today. Share this post Link to post Share on other sites
Filippo Meozzi 1 #3 Posted July 2, 2020 2 minutes ago, ebinmaine said: I have two inch thick aluminum spacers on my Cinnamon Horse. Also had to buy special lug nuts to fit inside the holes in the spacer. I think I've got maybe $65 in the whole thing? I can get you the links for what I bought later on today. thanks so much that would be much appreciated! 1 Share this post Link to post Share on other sites
roadapples 6,987 #4 Posted July 2, 2020 4.5"x5. I bought some on eBay for less than $20 a piece.... 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #5 Posted July 3, 2020 Yup, luckily the WH is the same as all the standard ford / jeeps. My old ranger was 5 x 4.5". 1 Share this post Link to post Share on other sites
ebinmaine 77,324 #6 Posted July 3, 2020 10 hours ago, Filippo Meozzi said: thanks so much that would be much appreciated! Pm sent Share this post Link to post Share on other sites
ebinmaine 77,324 #7 Posted July 3, 2020 The thing to watch on a horse is the opening in the center. They're fairly large at about 85/86 mm. I found spacers that have an 87.1mm center. Only thing is, I had to get specific lug nuts (internal hex) because a socket does not fit in the lug holes. Share this post Link to post Share on other sites
