JuneBuggyWuggy 2 #1 Posted June 24, 2020 (edited) 1992 520h will not stop pulling when brakes mashed Edited June 24, 2020 by JuneBuggyWuggy More information Share this post Link to post Share on other sites
rmaynard 16,372 #2 Posted June 24, 2020 Sounds like the transmission is not returning to the neutral position. 1 Share this post Link to post Share on other sites
953 nut 60,355 #4 Posted June 24, 2020 Download this file, it should be very helpful. Couple years older than yours but the transmission and brakes would be the same. 1 Share this post Link to post Share on other sites
rmaynard 16,372 #6 Posted June 24, 2020 It doesn't matter how much you push on the brake, if the transmission is still in forward it keeps going. That's why it's important to make sure that the linkage is returning to neutral as soon as you start braking. 2 1 Share this post Link to post Share on other sites
bottjernat1 2,194 #7 Posted June 24, 2020 (edited) I'd also check the belt it sounds like the clutch pedal isnt working right. Something is out of wack Edited June 24, 2020 by bottjernat1 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,522 #8 Posted June 24, 2020 More manuals Garry 2 Share this post Link to post Share on other sites
lynnmor 7,858 #9 Posted June 24, 2020 1 hour ago, bottjernat1 said: I'd also check the belt it sounds like the clutch pedal isnt working right. Something is out of wack A hydro doesn't have a clutch. Obviously the motion lever isn't returning to neutral when the brake pedal is pushed, the manuals above should show the adjustment. My brakes are like new on hydro tractors, the hydro does nearly all the braking. Share this post Link to post Share on other sites
bottjernat1 2,194 #10 Posted June 24, 2020 2 hours ago, lynnmor said: A hydro doesn't have a clutch. Obviously the motion lever isn't returning to neutral when the brake pedal is pushed, the manuals above should show the adjustment. My brakes are like new on hydro tractors, the hydro does nearly all the braking. my bad i had a tater head moment i know better. Share this post Link to post Share on other sites
bottjernat1 2,194 #11 Posted June 24, 2020 Is it a total different setup on the 520 then my daughters 69 electro 12? I have a video i did on how to adjust the neutral position on the tranny on my YouTube channel. Share this post Link to post Share on other sites
lynnmor 7,858 #12 Posted June 24, 2020 4 hours ago, bottjernat1 said: Is it a total different setup on the 520 then my daughters 69 electro 12? I have a video i did on how to adjust the neutral position on the tranny on my YouTube channel. Totally different, you adjust the cam that rides in the cam plate, and if needed, the linkage. Share this post Link to post Share on other sites
