923cuda 0 #1 Posted June 23, 2020 (edited) Hi I am looking for a tiller and all that brackets I need to hook one up.Any help would be appreciated. How do you tell which tiller will fit. Edited June 23, 2020 by 923cuda Spelling Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #2 Posted June 23, 2020 In 1985 the tiller sold for your tractor was model 07-36TL02 Here is a list of the tillers in the order they were produced. Any later than 1985 will definitely fit and some older possibly. The biggest difference is the hardware required to lift the tiller for transport. If you look at the parts list for each of them all the required parts are shown. 1973-1974 tiller model 7-1251 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1975 tiller model 7-1252 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1976 tiller model 67-36TL01 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1977 tiller model 77-36TL01 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1977 tiller model 77-36TL02 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1978 tiller model 87-36TL01 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1979 tiller model 97-36TL01 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1980-1982 tiller model 07-36TL01 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1983-1985 tiller model 07-36TL02 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1986-1989 tiller model 07-36TL03 [Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1990-1991 tiller model 07-36TL04 [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1992 tiller model 07-36TL05 [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] 1993-2001 2003-2007 tiller model 79370 [Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")] Garry 1 Share this post Link to post Share on other sites
923cuda 0 #3 Posted June 23, 2020 Thank you very much for the info. Do you know if I need anything for attaching the tiller. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #4 Posted June 23, 2020 The rear axle hitch is the same as the one used for the dozer blade so you may already have that. Here is a parts list for the 07-36TL02. You will see everything required. https://www.partstree.com/models/07-36tl02-toro-36-tiller-1984/ Garry Share this post Link to post Share on other sites
darjphunter@aim.com 0 #6 Posted July 6, 2020 I am looking for gear box parts and slip clutch for 50inch rear tiller can any one help me out?? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #7 Posted July 6, 2020 One of these tillers? Garry Share this post Link to post Share on other sites
