johnnymag3 2,644 #51 Posted June 23, 2020 Valves are adjusted......, they were never really off... just giving up on this thing. Share this post Link to post Share on other sites
johnnymag3 2,644 #52 Posted June 23, 2020 Ive got a MAGNUM Headache 1 Share this post Link to post Share on other sites
bc.gold 3,406 #53 Posted June 23, 2020 31 minutes ago, johnnymag3 said: Ive got a MAGNUM Headache Share this post Link to post Share on other sites
Bill D 2,747 #54 Posted June 24, 2020 Pull the valves. Clean them with a wire wheel, lap them and reinstall. I think a valve is hanging up at low speed. Bill 2 1 Share this post Link to post Share on other sites
johnnymag3 2,644 #55 Posted June 24, 2020 1 hour ago, Bill D said: Pull the valves. Clean them with a wire wheel, lap them and reinstall. I think a valve is hanging up at low speed. Bill Taking your advice, going to try to do that today.....I have a new head gasket, and it should be an easy job. Hood is off, carb is off.... thanks Bill ! 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #56 Posted June 24, 2020 I understand your frustration, but it sounds like this tractor just pushes snow which is at full throttle anyway. If it runs good and doesn't get hot or anything, what would be the point of replacing an engine over it. I have more cheapskate in me than OCD! The valve hanging at low rpm's sound possible. Randy Share this post Link to post Share on other sites
johnnymag3 2,644 #57 Posted June 24, 2020 This guy does not run full throttle to plow, he eases into everything....so fussy where the snow goes...etc. Its very annoying to have to use full throttle, and me and my OCD wont give this guy a tractor back thats not 100 PERCENT ! There has to be a simple thing to be happening, but Ive never had this situation in over 40 years !! Going to dig in to it soon, after dinner......... Thank you everyone, and keep the ideas a comi'n !!! 1 Share this post Link to post Share on other sites
ebinmaine 78,272 #58 Posted June 24, 2020 18 minutes ago, johnnymag3 said: eases into everything I know it's not my money or my time but I'm really looking forward to you figuring out what's going on with that engine. I hope it's solution comes up. Just as a point of interest about the RPM speed on these engines. It's important to remember that they are air-cooled and do not have a pressure oiling system. They are dependent on the crankshaft spinning to sling the oil around internally. Kohler as a company recommends running them at full throttle when under any kind of a load. I don't necessarily subscribe to that exactly but I NEVER run an engine on any tractor at less than half throttle while the machine is moving. A moving tractor is literally considered "under load." A hydro or automatic tractor in particular should never run below 3/4 or full throttle when moving because the transmission has a fan that needs to be moving air and fluid to keep that hydraulic pump cool. 2 Share this post Link to post Share on other sites
bc.gold 3,406 #59 Posted June 24, 2020 (edited) On 6/24/2020 at 3:02 PM, johnnymag3 said: This guy does not run full throttle to plow, he eases into everything These air cooled engines are meant to be run at high rpm, operating at low rpm's during the cold season the engine barely gets up to operating temp. Your engine is carbonated - coked up. The vacuum gauge would have pointed you in this direction and saved you hours of frustration. Exhaust valve hanging up in the guide, possibly coated with un-burnt carbon on the valve head. Clean the valve and guide free of carbon then inform your fussy guy not to spare the horse's. Edited June 26, 2020 by bcgold Share this post Link to post Share on other sites
johnnymag3 2,644 #61 Posted June 26, 2020 Some pics for you to peruse.......As I suspected with this many hours Share this post Link to post Share on other sites
johnnymag3 2,644 #62 Posted June 26, 2020 I tried to send more pictures, but I m only allowed a certain amount of MB....go figure Share this post Link to post Share on other sites
johnnymag3 2,644 #63 Posted June 26, 2020 I also found that the coil wire from the coil is rock hard, and wont bend Share this post Link to post Share on other sites
ebinmaine 78,272 #64 Posted June 26, 2020 15 minutes ago, johnnymag3 said: only allowed a certain amount of MB Of you become a supporter the limit goes away and so do the ads. It helps keep the lights on around here!! 2 1 Share this post Link to post Share on other sites
johnnymag3 2,644 #65 Posted June 26, 2020 19 minutes ago, ebinmaine said: Of you become a supporter the limit goes away and so do the ads. It helps keep the lights on around here!! Sign me up !!! im good for 2 years, and if I live long enough, I will do another 2 1 1 Share this post Link to post Share on other sites
johnnymag3 2,644 #66 Posted June 26, 2020 Just now, johnnymag3 said: Sign me up !!! im good for 2 years, and if I live long enough, I will do another 2 I love this place and all of you around it....its like a free ride to heaven 1 1 Share this post Link to post Share on other sites
ebinmaine 78,272 #67 Posted June 26, 2020 2 minutes ago, johnnymag3 said: Sign me up !!! im good for 2 years, and if I live long enough, I will do another 2 Should be a tab at the top of the page that says Redsquare store or RS store. 1 Share this post Link to post Share on other sites
johnnymag3 2,644 #68 Posted June 26, 2020 MEMBERSHIP PAID !!!!! LETS GET THIS DONE BOYS, WICKED COOL 1 Share this post Link to post Share on other sites
ebinmaine 78,272 #69 Posted June 26, 2020 Your name looks great in RED! 1 1 Share this post Link to post Share on other sites
photoguy 163 #70 Posted June 26, 2020 I had one doing close to the same thing turned out the coil was bad.If you have one you no is good worth a try,wire and all. 2 1 Share this post Link to post Share on other sites
JCM 11,117 #71 Posted June 26, 2020 @johnnymag3 Not to get off topic but I hope when you retire you will consider making an appearance at the N. Berwick Maine Meet & Greet that would as we say be wicked awesome, and by the way nice one year only 418-A. 1 1 Share this post Link to post Share on other sites
johnnymag3 2,644 #72 Posted June 26, 2020 (edited) 56 minutes ago, ebinmaine said: Your name looks great in RED! As does yours my friend in Maine @!!!!!! Edited June 26, 2020 by johnnymag3 1 Share this post Link to post Share on other sites
johnnymag3 2,644 #73 Posted June 26, 2020 23 hours ago, Bill D said: Any luck? This engine has like no hours....................The stem was spotless...both the valves Share this post Link to post Share on other sites
johnnymag3 2,644 #74 Posted June 26, 2020 the other pictures of the angry machine Share this post Link to post Share on other sites
johnnymag3 2,644 #75 Posted June 26, 2020 1 hour ago, ebinmaine said: Of you become a supporter the limit goes away and so do the ads. It helps keep the lights on around here!! I will help to keep the lights as often as it takes....no reserve 1 Share this post Link to post Share on other sites
