squonk 46,035 #26 Posted June 21, 2020 As belts wear they get thinner. This is what everybody thinks is "the belt stretched" Belts do not stretch. When the sides wear in too far they don't grip the sheaves so the only gripping point is the inside of the belt which is not designed to grip. When you get the guard off, lets see a pic of the belt. 1 Share this post Link to post Share on other sites
daveoman1966 3,882 #27 Posted June 21, 2020 Another reason I like my C-160 Auto.... does not free-wheel on down-slopes. Share this post Link to post Share on other sites
Jhatch13 31 #28 Posted June 21, 2020 2 minutes ago, daveoman1966 said: Another reason I like my C-160 Auto.... does not free-wheel on down-slopes. I would expect this out of a hydrostatic, a uni-drive with an 8 speed gear box.....not so much Share this post Link to post Share on other sites
Jhatch13 31 #29 Posted June 21, 2020 44 minutes ago, squonk said: As belts wear they get thinner. This is what everybody thinks is "the belt stretched" Belts do not stretch. When the sides wear in too far they don't grip the sheaves so the only gripping point is the inside of the belt which is not designed to grip. When you get the guard off, lets see a pic of the belt. Heres a few Share this post Link to post Share on other sites
Tractorhead 9,217 #30 Posted June 21, 2020 If the lower Pict is with engaged clutch, than the Belt is definitiv too loose. I see a wear on belt undersite, but on that picts i cannot exactly see how the belt fit‘s into the Pulley as @squonk mentioned. when the belt touches the Pulley bottom on the lower side, than it‘s a to worn belt or even a wrong sized Belt try a pic along the belt facing to the Pulley, to see how it fits. but as far as i can see on that Picts it seems it‘s to worn. what i see so far is firstly a to loose Belt, that causes in a lost friction, what explains also your traction loss. The to loosen belt can be also seen on the upper Pict, short after the Pulley. there is a lightly wave, what shouldn‘t be. Share this post Link to post Share on other sites
Jhatch13 31 #31 Posted June 21, 2020 1 minute ago, Tractorhead said: If the lower Pict is with engaged clutch, than the Belt is definitiv too loose. I see a wear on belt undersite, but on that picts i cannot exactly see how the belt fit‘s into the Pulley as @squonk mentioned. when the belt touches the Pulley bottom on the lower side, than it‘s a to worn belt or even a wrong sized Belt try a pic along the belt facing to the Pulley, to see how it fits. but as far as i can see on that Picts it seems it‘s to worn. what i see so far is firstly a to loose Belt, that causes in a lost friction, what explains also your traction loss. The to loosen belt can be also seen on the upper Pict, short after the Pulley. there is a lightly wave, what shouldn‘t be. Both pictures were with the clutch pedal not being depressed. Share this post Link to post Share on other sites
Tractorhead 9,217 #32 Posted June 21, 2020 Ok, than you found your problem. next thing is solve it. look along the Belt, if it touches the pulley inside with Belt bottom, it‘s to worn or wrong belt size Share this post Link to post Share on other sites
Jhatch13 31 #33 Posted June 21, 2020 It started storming here so I had to put it back together and bring it inside ( limited space to work it the garage). This is from the front side of the pulley (towards the grille pointing camera towards the rear end). The clutch was not depressed in this picture either. Share this post Link to post Share on other sites
Tractorhead 9,217 #34 Posted June 21, 2020 No, i meant from the other side, where the belt is running into pulley. Share this post Link to post Share on other sites
Jhatch13 31 #35 Posted June 21, 2020 Just now, Tractorhead said: No, i meant from the other side, where the belt is running into pulley. I will have to take the belt guard off later and get another picture. Thanks for the diagnosis! Share this post Link to post Share on other sites
Tractorhead 9,217 #36 Posted June 21, 2020 Try also if there is a play in the belt spanner. The spring must pull the spanner to the Belt with a bit of Force so about 2-4 Kilos. if there is a play, maybe just your spring is a bit lame Share this post Link to post Share on other sites
Stormin 9,987 #37 Posted June 21, 2020 1 hour ago, Jhatch13 said: If only light pressure, if any, is on that belt, then to my mind it's well slack. The top will be tight under forward drive, but the bottom will be flapping about like mad. Share this post Link to post Share on other sites
squonk 46,035 #38 Posted June 21, 2020 23 minutes ago, Jhatch13 said: It started storming here so I had to put it back together and bring it inside ( limited space to work it the garage). This is from the front side of the pulley (towards the grille pointing camera towards the rear end). The clutch was not depressed in this picture either. That belt is sitting too low in the pulley. Replace it Share this post Link to post Share on other sites
Jhatch13 31 #39 Posted June 21, 2020 47 minutes ago, Tractorhead said: No, i meant from the other side, where the belt is running into pulley. Here is the front and rear pulley. Excuse my lack of photography skills. The belt measures 3/8 on the bottom of the "V" and 1 inch on the top. I believe 5/8 is what it should be. Share this post Link to post Share on other sites
953 nut 65,061 #40 Posted June 21, 2020 it seems to me that the laws of physics can't be overlooked here. When the engine is transferring power to the transmission the lower half of the belt is doing the work. Your engine pulley is turning counter clockwise PULLING the belt toward it. The belt clutch tensioner is just taking up the slack on the lag side of the belt. When you are headed down hill the engine is turning the same direction but slower than the transmission so the lag is on the bottom half of the belt and the driven tension is being applied to the spring loaded clutch tensioner on the top half of the belt. Your owner's manual tells you to avoid steep grades. Be safe and follow the manufacturer recommendations . 2 1 Share this post Link to post Share on other sites
Jhatch13 31 #41 Posted June 22, 2020 (edited) 53 minutes ago, 953 nut said: it seems to me that the laws of physics can't be overlooked here. When the engine is transferring power to the transmission the lower half of the belt is doing the work. Your engine pulley is turning counter clockwise PULLING the belt toward it. The belt clutch tensioner is just taking up the slack on the lag side of the belt. When you are headed down hill the engine is turning the same direction but slower than the transmission so the lag is on the bottom half of the belt and the driven tension is being applied to the spring loaded clutch tensioner on the top half of the belt. Your owner's manual tells you to avoid steep grades. Be safe and follow the manufacturer recommendations . Below is what my owners manual says. According to #44, im doing everything that I should be (aside from being able to mow uphill, not ascending backwards) in regards to mowing downhill, and its not working currently. Edited June 22, 2020 by Jhatch13 Share this post Link to post Share on other sites
skrusins 128 #42 Posted June 22, 2020 I have several steep hills. I find that if I try going down forward my 312-8 slides and turfs up the lawn even applying the brakes. I go up the steep part of the hill forward and back down backward. I feel that I have more control then I use second gear to finsh the hill. 1 Share this post Link to post Share on other sites
Jhatch13 31 #43 Posted June 22, 2020 2 minutes ago, skrusins said: I have several steep hills. I find that if I try going down forward my 312-8 slides and turfs up the lawn even applying the brakes. I go up the steep part of the hill forward and back down backward. I feel that I have more control then I use second gear to finsh the hill. This hill is fairly long and somewhat steep. Im afraid that if I backed down it, i may get the same result, or have it flip over and land on top of me. Ill probably just stick with the 211 until it breaks. At least i know it works. The 312 is in too nice of shape to keep trying and have something break or roll out of control and flip. If i can find a snow blade locally i may keep it for plowing, but I may just sell it. Share this post Link to post Share on other sites
skrusins 128 #44 Posted June 22, 2020 Did you try to go up and down the hill at a angle by shifting your weight on the seat instead of straight. I do that on some of my hills. Share this post Link to post Share on other sites
lynnmor 8,736 #45 Posted June 22, 2020 Hopefully someone will buy it, tighten up the belt and have a good tractor. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,123 #46 Posted June 22, 2020 If this tractor has a dampener on the idler pulley it is likely misadjusted for a worn belt or the dampener is sticking. The first ones were an air shock and you can wash them out so they work again. It is a dusty environment for this type of shock. Garry 1 1 Share this post Link to post Share on other sites
Jhatch13 31 #47 Posted June 22, 2020 3 minutes ago, lynnmor said: Hopefully someone will buy it, tighten up the belt and have a good tractor. Hopefully they wont have any steep grades to use it on. I dont think that changing the belt is going to make that big of difference as far as my hill is concerned. Everyone who owns the same model seems to have the similar issues, regardless of the belt being new or worn. I would also add AG tires, but if i end up with the same result thats alot of money for nothing. I think that the greater friction from the 211s setup, the lower center of gravity, and the ability to put all my weight over the rear wheels helps versus the larger 312. It just may not work for what I need out of it. Better that it goes to someone who can use it than to sit or get damaged. 1 1 Share this post Link to post Share on other sites
Darb1964 1,166 #48 Posted June 22, 2020 I have seven wheel horse tractors three c series, ten, eleven and twelve HP. With eight speeds. A three hundred, four hundred and two five hundred series with hydro and eight speeds.every one will go up or down a steep grade, I have a hill that is probably a little steeper than recommended and they will go up or down that hill with out free wheeling. I weigh two hundred give or take a few. A three hundred pounder results may be different. I think you need a new belt or adjustment free wheeling is not normal under normal working conditions. 2 1 Share this post Link to post Share on other sites
tom2p 2,394 #49 Posted June 22, 2020 (edited) have a 312-8 that I've used since late 90's including up and down hills no issues - engine / transmission braking works well do have to be careful when grass is wet and when applying brake though - too much brake and one rear wheel will often lock (and / or begin to spin backward) best to use brake sparingly or no brake - and allow engine / transmission to provide brake I use Wheel Horse OEM belt - off-white belt with Wheel Horse and part number stamped on a small black rectangular part of the belt Edited June 22, 2020 by tom2p 1 Share this post Link to post Share on other sites
kasey54 305 #50 Posted June 22, 2020 I have loaded and unloaded lots of gear drives on much steeper ramps than the tractor should be driven on. The only time they free wheel is with too little belt tension. If you determine if its a tensioner problem , or too long of belt or too worn fix it you will have no issues except traction. Then one wheel will skid or turn backwards. Don't give up on it. 2 Share this post Link to post Share on other sites
