Phil53 7 #1 Posted June 17, 2020 I have a 520 wheel horse and want to plow snow with it, there is no clearance for tire chains, does any one know what size tire I need so I have clearance for tire chains Share this post Link to post Share on other sites
oliver2-44 11,076 #2 Posted June 17, 2020 Please share what tires are on it now. Share this post Link to post Share on other sites
ebinmaine 75,873 #3 Posted June 17, 2020 5 hours ago, oliver2-44 said: Please share what tires are on it now. Is your clearance issue on the inside or to the top? If it's the inside you could pick up a set of wheel spacers. Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #4 Posted June 17, 2020 9 hours ago, Phil53 said: I have a 520 wheel horse and want to plow snow with it, there is no clearance for tire chains, does any one know what size tire I need so I have clearance for tire chains I've never had a clearance issues with chains on a 520H and stock size tires. Share this post Link to post Share on other sites
Phil53 7 #5 Posted June 17, 2020 the tires one my tractor are 23 X 10.50-12. the issue is on the inside the chains almost clear, The tires need replaced this is why I looking into the tire size I think according to the manual the tires that are on are the correct size. I neve give the wheel spacer a thought might have to look into them Share this post Link to post Share on other sites
troutbum70 858 #6 Posted June 17, 2020 Maybe axle hubs are set to far in? Maybe move them out a half inch? 1 Share this post Link to post Share on other sites
lynnmor 8,270 #7 Posted June 17, 2020 I have used regular chains, V-bar chains and rubber chains on 2 ply and 4 ply squared shouldered tires of that size on three different 520H's. I'm just down the road if you want to see them. 2 1 Share this post Link to post Share on other sites
Lee1977 7,462 #8 Posted June 17, 2020 Old 2 ply tires belle out and up like a beach ball i took a set off my 520 right after I go it. As for moving hubs they should be flush with the ends of the axles. The design with the woodrulff keys the set screw should be centered on the key. If moved the set screw will cock the key allowing the hub to move. So line up the hubs with the ends of the axle and don't move them. Share this post Link to post Share on other sites
ebinmaine 75,873 #9 Posted June 17, 2020 1 hour ago, Phil53 said: spacer I bought a couple sets. Let me know if you want more information by p.m. Share this post Link to post Share on other sites
Phil53 7 #10 Posted June 17, 2020 what is the cost of a set of spacers Share this post Link to post Share on other sites
ebinmaine 75,873 #11 Posted June 17, 2020 45 minutes ago, Phil53 said: what is the cost of a set of spacers The most recent ones I bought were 2" thick. I wasn't careful enough when I read the listing and I had to buy lug nuts as well. Total cost I think was about $60, $65. If you can get away with a thinner spacer and you are more careful than I was you could probably do it for more like $30, $35. I'd be glad to take some pictures and show you what I mean. Might take me a couple days to get to it. Share this post Link to post Share on other sites
