Mr Magoo 226 #1 Posted June 14, 2020 I have all the parts for the headlight assembly for my C-120, but not sure exactly how it was all mounted and held together. When I got the tractor, the bucket was held in with baling wire and I'm pretty sure that's not stock. What holds the bucket to the hood? I thought it looked like it was maybe rivets. Is there supposed to be any kind of gasket or cushion in there too? I can see on the exploded parts view that the bezel was held in with screws, but not sure what size. Are they threaded into the bezel? Lastly, what kind of splitter or plug do you all use for going from the lights to the switch? Seems like it should be a plug there so you can remove the hood easily. Thanks! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #2 Posted June 14, 2020 You can get a 2-wire trailer connector that works well. Like the common flat 4-wire trailer connector but just 2 wires. Garry 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #3 Posted June 15, 2020 (edited) Bucket should be riveted to the hood, 1/8" rivets, one per side. The screws that hold the lens go through the lens, through the hood, and thread into the bucket housing. This allows you to remove the lens (4 screws in the corners) to swap bulbs, and the 2 rivets hold it in place on the hood. Edited June 15, 2020 by 71_Bronco 1 Share this post Link to post Share on other sites
WHX?? 53,346 #4 Posted June 15, 2020 On 6/14/2020 at 7:48 AM, gwest_ca said: Like the common flat 4-wire trailer connector but just 2 wires. Or common bullet connectors. Make sure you ground the bucket back to the frame or and other good ground especially if running led bulbs or they will flicker. not so if running incandescent but be careful with those they have been know to create problems with the lens. Share this post Link to post Share on other sites
Mr Magoo 226 #5 Posted June 15, 2020 6 hours ago, WHX24 said: Or common bullet connectors. Make sure you ground the bucket back to the frame or and other good ground especially if running led bulbs or they will flicker. not so if running incandescent but be careful with those they have been know to create problems with the lens. Thank you. I was going to use the 1156 bulbs, but not if they will screw up my lens. Is there a particular brand of LED that is good? Share this post Link to post Share on other sites
