BrianX128 113 #1 Posted June 13, 2020 Anyone ever have their eaton 1100 leak around the two fittings near the transmission filter? Mine is dropping a drop ever 10 or so seconds, I tried tightening things up some but no luck. Are there replaceable seals inside those connections? 1 Share this post Link to post Share on other sites
stevasaurus 23,536 #2 Posted June 13, 2020 I'm not familiar with the Eaton transmissions, but if you go to the Reference Section...Manuals...Transmissions...Manual, we have some Eaton 1100 manuals that should answer your questions. 2 Share this post Link to post Share on other sites
squonk 45,119 #3 Posted June 13, 2020 I think the lines are flare fittings. Most likely is a cracked flare 1 Share this post Link to post Share on other sites
