Bow_Extreme 580 #1 Posted June 12, 2020 Question: If any at all, what is the difference between the HC swept front axle and the 91’ and newer swept front axle? Are they the same? Is one wider than the other? I believe both have 1” spindles. Anyone laid them next to each other for comparison? Share this post Link to post Share on other sites
Lee1977 7,552 #2 Posted June 13, 2020 (edited) I would guess the cast iron axles are the same. It's a Wheel Horse tradition not to change things once a design has been chosen. Edited June 13, 2020 by Lee1977 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,998 #3 Posted June 13, 2020 HC axle 112762 replaced by 116823 1990 axle 116823 replaced by 116823-01 Garry 2 Share this post Link to post Share on other sites
Bow_Extreme 580 #4 Posted June 13, 2020 (edited) 1 hour ago, gwest_ca said: HC axle 112762 replaced by 116823 1990 axle 116823 replaced by 116823-01 Garry Basically, they are the same. Thank You! Edited June 13, 2020 by Bow_Extreme Share this post Link to post Share on other sites
cleat 8,733 #5 Posted June 13, 2020 I have both here and I can't tell the difference. Tie rods are the same as well. Steering is the difference, HC does not have the reduction. Cleat 1 Share this post Link to post Share on other sites
Bow_Extreme 580 #6 Posted June 13, 2020 8 hours ago, cleat said: I have both here and I can't tell the difference. Tie rods are the same as well. Steering is the difference, HC does not have the reduction. Cleat Thank You Very Much, Cleat! Share this post Link to post Share on other sites
