OldManLogan 0 #1 Posted June 8, 2020 I have a 310 – 8 has a m10s Kohler motor what else can I put under the hood of his tractor will a M16 fit underneath there and bolt up and I want to make it look as stock as possible I don't have no modify the hood of the frame the compromise strength or integrity Share this post Link to post Share on other sites
clueless 3,388 #2 Posted June 8, 2020 The M16 is the same size a the M10 just more hp. So fitting would not be a problem, Now there may be some differences in the charging system and some other things, but the basic size is the same. 2 Share this post Link to post Share on other sites
OldManLogan 0 #3 Posted June 8, 2020 thanks is there a particular year or model to search for Share this post Link to post Share on other sites
bds1984 1,506 #4 Posted June 9, 2020 The only primary concern I'd have is making sure the crankshaft is long enough. I have come across a few M16s that could have been had for almost free, but the cranks were either 1" long or tapered. Share this post Link to post Share on other sites
Pullstart 69,638 #5 Posted June 10, 2020 Michigander! @8ntruck is in your neck of the woods during some parts of the year, I grew up in Belding and went to MCC for a bit and spent a lot of time at Mid-Michigan drag racing my junk cars Share this post Link to post Share on other sites
pfrederi 20,253 #6 Posted June 11, 2020 On 6/8/2020 at 10:51 PM, bds1984 said: The only primary concern I'd have is making sure the crankshaft is long enough. I have come across a few M16s that could have been had for almost free, but the cranks were either 1" long or tapered. 2 Share this post Link to post Share on other sites
