JJMason84 3 #1 Posted May 27, 2020 Engine starts runs rough, turns over but won’t stay running for some reason. Any thoughts? New plug, condenser, coil, fuel pump and filer Share this post Link to post Share on other sites
520hC-120 136 #3 Posted May 27, 2020 Definitely clean the carb out. Get some compressed air through there too. Share this post Link to post Share on other sites
bc.gold 3,406 #4 Posted May 27, 2020 Check valve tappet adjustment. Share this post Link to post Share on other sites
ebinmaine 74,551 #5 Posted May 27, 2020 2 hours ago, squonk said: Dirty carb That was my first thought as well. Ethanol is NOT your friend. Switch to ethanol free gas. Replace ALL fuel lines while you're there. 3 Share this post Link to post Share on other sites
kasey54 305 #6 Posted May 27, 2020 make sure fuel cap vent is working Share this post Link to post Share on other sites
JJMason84 3 #7 Posted May 28, 2020 (edited) 4 hours ago, bcgold said: Check valve tappet adjustment. Where would that be located on this engine? . Ya I opened the carb and it is nasty! I ordered a kit for it but going to try a do a good cleaning best I can Edited May 28, 2020 by JJMason84 1 Share this post Link to post Share on other sites
squonk 44,615 #8 Posted May 28, 2020 If you have the carburetor off they are behind the plate that was to the left of the carb held on with a single bolt. There are 2 gaskets and a baffle inside plus you need to know what you are doing in there and the parts have to go back in exactly as they come out. I wouldn't bother if you don't know what you're doing. Dollars to doughnuts it was the crappy carb. 2 Share this post Link to post Share on other sites
953 nut 62,157 #9 Posted May 28, 2020 Can you fill us in on some of the background. Has this engine run well lately or did you just get it and are getting it going? More than likely it is the Carburetor. The gap on your ignition points also sets the ignition timing, you may want check it again. If you have access to an automotive timing light that is the best way co assure the points are set properly. Share this post Link to post Share on other sites
ebinmaine 74,551 #10 Posted May 28, 2020 9 hours ago, JJMason84 said: Where would that be located on this engine? . Ya I opened the carb and it is nasty! I ordered a kit for it but going to try a do a good cleaning best I can One of the things I've told people for a long long time is that you need to do the maintenance before you do the repairs. I consider cleaning a carburetor on a small engine to be a maintenance item. Best way to do a carb clean is to soak it. If you don't have a way to do that, no worries. Pick up 3 cans of cheap carb cleaner or brake clean. I use brake clean because it's easier to get for less money in my area. Get a hold of a toothbrush. Might not want to reuse it after you do this or just make sure it belongs to your significant other, not you. Disassemble, remove the jets etc. Clean it until you think it is 99.9% spotless and then clean it again. I normally reserve one full can of brake clean to spray every possible which way and back again through all the galleys. 10 minutes ago, squonk said: Dollars to doughnuts it was the crappy carb. I like dollars and I also like donuts. I agree. Share this post Link to post Share on other sites
squonk 44,615 #11 Posted May 28, 2020 38 minutes ago, ebinmaine said: I normally reserve one full can of brake clean It's wasp and wood bee season. Shoots them down like Zero's in WWII movies! 1 Share this post Link to post Share on other sites
JJMason84 3 #12 Posted May 28, 2020 Thanks! I just got it, previous person said they did this. Of course not. It ran great then shut off after 2hrs or so of using it with the loader. So it was hot. Most recently the old tank ran dry of gas (prob sucked up stuff into the carb) and the front hydrolic pump belt broke , since then it runs rough when it’s actually running 1 Share this post Link to post Share on other sites
JJMason84 3 #13 Posted May 28, 2020 A good old carb cleaning did the trick! Now to see if it stalls when it gets hot! Loo 1 Share this post Link to post Share on other sites
