Mach1dave
Kohler 16hp K341 engine.
Mach1dave
Can anyone help me with why the engine always runs at high speed. Even if I drop throttle down to idle it still run at full speed.
is that a governor problem?  If so how can I fix it.
any help is appreciated.
thanks.
rjg854
Has always done this?  Have you made any recent adjustments to the throttle cable, or governor?
BTW :WRS:
Edited by rjg854
add
953 nut
:WRS:
Take a look at the linkage going from the throttle cable to the governor and from the governor to the throttle arm on the carburetor. If all of that is moving freely as it should I would suggest you remove the carburetor to see if the throttle plate has become jammed or fallen off.
