Elliot Garfinkel 166 #1 Posted May 24, 2020 Hi all pretty soon I will get rolling on the k161 rebuild are the connecting rods all the same or the bore will determine that.I know their are two #s one standard and one for .010 but what if the bore is more I guess you use the second option for all oversized pistons . Thanks Share this post Link to post Share on other sites
stevasaurus 23,662 #2 Posted May 24, 2020 In the case of the connecting rods...if you have the journal turned on the crank shaft, then you need to order the correct connecting rod to fit the newly turned journal. The Machinist will tell you which is right. The piston end of the connecting rods are all the same. The machinist will also tell you what piston to order. 1 Share this post Link to post Share on other sites
richmondred01 2,360 #3 Posted May 24, 2020 (edited) Unless you can find a NOS rod, current replacement rods only come in .010 over. (Several us old guys have them squirreled away but they no longer make rods .020 and above). Piston and rings are available up to .030. K161/181 are non adjustable valves so they will have to be fitted. Additionally, the vast majority of the 161 and 181 engines, that I rebuild, require valve guides. Be prepared to have it bored, crank ground, new guides knocked in and valve seats ground. no sense of doing it if it’s not done right. Edited May 24, 2020 by richmondred01 1 2 1 Share this post Link to post Share on other sites
Elliot Garfinkel 166 #4 Posted May 24, 2020 Okay thanks I didnt plan on valve guides but I dont think that should be a problem everything else will be new crankshaft camshaft ,planned on having cylinder bored,valve seats done right now existing piston is standard so their is a difference between STD and 0.010 on rod , starting to get a feeling I might be in over my head ,kind of got alot tied up in this motor so far and I'm still haven't had it machined yet Thanks for the response Share this post Link to post Share on other sites
richmondred01 2,360 #5 Posted May 24, 2020 (edited) I don’t understand. You have a “new” crankshaft? If the crankshaft is new then it should be standard and you shouldn’t need it turned. Edited May 24, 2020 by richmondred01 Share this post Link to post Share on other sites
Elliot Garfinkel 166 #6 Posted May 24, 2020 I didnt plan on turning old crank I was installing new. just wanted cyl bore,valve seats new piston ,rings I guess I'll know more once I can hook up with a machinist Share this post Link to post Share on other sites
richmondred01 2,360 #7 Posted May 24, 2020 A new crank or new rod.? Share this post Link to post Share on other sites
Elliot Garfinkel 166 #8 Posted May 24, 2020 I planned on installing everything new but I have a standard piston now and after the bore I thought I would have to go to a 0.10 over piston and the rod seems to be available in standard and 0.10 just didnt know what the bore relation to rod size would matter this is my first attempt at this just trying to cut down on learning curve Thanks Share this post Link to post Share on other sites
richmondred01 2,360 #9 Posted May 24, 2020 The rod is dependent on the crankshaft journal not the piston. Share this post Link to post Share on other sites
Elliot Garfinkel 166 #10 Posted May 24, 2020 Oh I understand I appreciate your patience. Once I track down a machinist I guess I'll have a better understanding of the whole process. Share this post Link to post Share on other sites
Elliot Garfinkel 166 #11 Posted May 25, 2020 Hi guys at the bottom of the oil pan found these 2 pcs of aluminum looks like they came from rod assembly, I'm not sure if they are supposed to act as a paddle or they act as a lock . Thanks again for your continued help Share this post Link to post Share on other sites
richmondred01 2,360 #12 Posted May 25, 2020 Well now that's something new. Thats not from the rod and shouldn't be in there. Share this post Link to post Share on other sites
Elliot Garfinkel 166 #13 Posted May 25, 2020 (edited) I'm not sure if you can tell from pic but at the 2 bolts the ends look like it broke off of those two ends Edited May 25, 2020 by Elliot Garfinkel Forgot pic Share this post Link to post Share on other sites
richmondred01 2,360 #14 Posted May 25, 2020 (edited) Ok. Makes sense now. The photo is deceiving. It's the lock for the rod nuts. they look larger then they really are Edited May 25, 2020 by richmondred01 Share this post Link to post Share on other sites
Elliot Garfinkel 166 #15 Posted May 25, 2020 Ok thanks so the new ones have it and after the nuts are tightened (torqued)they get bent to lock the nuts.Do they usually break off or was it hitting the bottom of the pan. Thanks again for your help Share this post Link to post Share on other sites
richmondred01 2,360 #16 Posted May 25, 2020 Only if you have a NOS Kohler. after market ones have bolts not nuts. Share this post Link to post Share on other sites
Elliot Garfinkel 166 #17 Posted May 25, 2020 Okay thanks really appreciate the come back,trying to get it right Share this post Link to post Share on other sites
c-series don 11,823 #18 Posted May 26, 2020 I believe I have the proper connecting rod NOS and I’m less than an hour away. I’ll check the part number on the box. Check to see what it should be. I’m in Southampton with the largest collection of Wheel Horses on Long Island! 1 Share this post Link to post Share on other sites
Elliot Garfinkel 166 #19 Posted May 26, 2020 Hi don thanks for reply I ordered one already but nowadays that always dont mean anything.I spoke with you over the winter about finding a machinest.i had told you if I find one I'll pass the name along you gave me a name of a guy in Hampton bays but I spoke with someone in deerpark who said he could do it.Im still hesitant and might need someone to reassemble which I might have but I'm really looking for someone who has done a lot of these.will let you know if the machinest works out.Thanks for the offer and if it dont work out I'll take you up on the part 1 Share this post Link to post Share on other sites
richmondred01 2,360 #20 Posted May 26, 2020 2 minutes ago, Elliot Garfinkel said: Hi don thanks for reply I ordered one already but nowadays that always dont mean anything.I spoke with you over the winter about finding a machinest.i had told you if I find one I'll pass the name along you gave me a name of a guy in Hampton bays but I spoke with someone in deerpark who said he could do it.Im still hesitant and might need someone to reassemble which I might have but I'm really looking for someone who has done a lot of these.will let you know if the machinest works out.Thanks for the offer and if it dont work out I'll take you up on the part what did the crank mic out at? Share this post Link to post Share on other sites
Elliot Garfinkel 166 #21 Posted May 26, 2020 I didnt physically measure it it is a brand new crank I got a standard rod and one that is .010 to keep one or other for future as nos parts are getting hard to find and won't get any cheaper.Im into this for alot(you guys have been through it) so what's a little more Share this post Link to post Share on other sites
