89whowner 1 #1 Posted May 23, 2020 PTO started smoking and the outer bearing is shot. How do I go about replacing it? Share this post Link to post Share on other sites
lynnmor 8,307 #2 Posted May 23, 2020 8 minutes ago, 89whowner said: PTO started smoking and the outer bearing is shot. How do I go about replacing it? Remove the PTO brake and slide the bell off the tractor. Remove the retaining ring, then drive the bearing out from the back side. You should be able to see the number on the bearing and a TSC Store might have it. 2 Share this post Link to post Share on other sites
cleat 8,230 #3 Posted May 23, 2020 Bearing is 204RR6 I have replaced several. Cleat 1 Share this post Link to post Share on other sites
squonk 44,984 #4 Posted May 24, 2020 Napa # p204rr6 1 Share this post Link to post Share on other sites
Lee1977 7,465 #5 Posted May 24, 2020 1 hour ago, squonk said: Napa # p204rr6 Or a Z9504RST with SS seals is the same size bearing 3/4" ID x 1 25/32" OD x 39/64" thick (.75 ID x 1.781 OD x .609 ) or Z9504B with rubber seals 1 Share this post Link to post Share on other sites
89whowner 1 #6 Posted May 24, 2020 Any advice for driving it out? I'm new to this. Share this post Link to post Share on other sites
