Countdown To Christmas!
D250power
D200
D250power
I have a D200 with a Kohler, it has points is it possible to convert it to electronic ignition. Having a lot of problems with the points
ZXT
I don't know of an electronic ignition conversion (someone else will chime in), but what problems have you been having with your points? They're rarely problematic aside from general maintenance. We can probably help you get your current setup in good shape.
pacer
Goodness yes! Generally a guy will ask how to convert from electronic to points, they are so much more simple.
Give us some description of what its doing . Off hand seems the 2 wire coil is a bit prone to give problems,  ---- but, its just to hard to help with out a little info.
Pullstart
Is your coil internally resisted?  If it’s a coil meant for an external resistor, it can burn the points out in a quick hurry.
