Danedg 20 #1 Posted May 19, 2020 The Kohler 8hp started belching oil. Where do I get a replacement? Share this post Link to post Share on other sites
stevasaurus 23,518 #2 Posted May 19, 2020 Put an add in the wanted section on this site. You might also take a look in the for sale section...might be one there. I would take the head off and see what happened. If the block is OK, these are fixable and parts are available. Put some pictures up here if you take the head off. It is a good idea to take lots of pictures as you tear it down...sheet metal, wires, cables, drive belt and guard. This might be an easy fix, and then you will have to put it back together. 1 Share this post Link to post Share on other sites
ebinmaine 75,857 #3 Posted May 19, 2020 1 hour ago, Danedg said: started belching oil. Like Steve says above. Do you know what's exactly wrong? Share this post Link to post Share on other sites
bottjernat1 2,196 #4 Posted May 19, 2020 Rebuild it! https://isavetractors.com/ultimate-engine-rebuild-kit-kohler-k181-8hp/ Share this post Link to post Share on other sites
Danedg 20 #5 Posted May 20, 2020 Thank you gents! I didn't know where to start.... Share this post Link to post Share on other sites
rmaynard 16,700 #6 Posted May 20, 2020 20 hours ago, Danedg said: The Kohler 8hp started belching oil. Where is the oil belching from? 1 Share this post Link to post Share on other sites
