kasey54 305 #1 Posted May 18, 2020 Good morning ladies and gents. Does anyone know if a reg. from a kohler magnum can be bench tested ? If so how? Share this post Link to post Share on other sites
Achto 31,314 #2 Posted May 18, 2020 22 minutes ago, kasey54 said: Does anyone know if a reg. from a kohler magnum can be bench tested ? If so how Normally I test them on the tractor. Unplug it, test the two wire coming from the engine to the regulator. these should have 30+ volts AC with the engine running 3/4 throttle or better. Next test the remaining wire in the plug, with the key in the run position you should have battery voltage from this wire to ground. Last but not least make sure that the body of the regulator is well grounded, and that all of the terminals are clean.. If all of the above check out but it still won't charge, then I would replace the regulator. 2 Share this post Link to post Share on other sites
kasey54 305 #4 Posted May 18, 2020 Its good. Was a bad fuse holder. 2 1 Share this post Link to post Share on other sites
