ebinmaine 77,079 #1 Posted May 17, 2020 Can a K341 (or other Kohler) be adjusted to make the governor react quicker than factory settings? Share this post Link to post Share on other sites
Stormin 9,987 #2 Posted May 17, 2020 Yes! By moving the spring to different holes. Closer or further apart. 1 Share this post Link to post Share on other sites
Lee1977 7,544 #3 Posted May 17, 2020 Eric what do you need it to react quicker for? You only use it to push snow and pull a trailer that only uses around 7 or 8 HP. You have to load it up with some to do like a snow blower or deck in heavy grass to get the governor to kick in. Maybe you want to know if it works. 1 1 Share this post Link to post Share on other sites
Pullstart 68,778 #4 Posted May 17, 2020 Eric... are you trying to limit the top RPM? If you adjust the governor shaft outward all the way, but don!t adjust the throttle shaft wide open, that might help. To change the way it reacts, I’d imagine you would have to lighten up the weights spinning inside the engine that the governor shaft reacts to. otherwise, I think a throttle stop might help as well. 1 Share this post Link to post Share on other sites
ebinmaine 77,079 #5 Posted May 17, 2020 2 hours ago, pullstart said: limit the top RPM Nope... That's set fine. What I'm after is to get the engine to pick up speed a little faster under load. When I'm hauling a trailer of wood up the hills it seems to falter more than it should. I'd like the governor to have a faster reaction time. The hole set from the factory is quite worn. I'd like to move the spring to the next fastest set. Share this post Link to post Share on other sites
tunahead72 2,600 #6 Posted May 18, 2020 Eric, I think you're talking about adjusting the governor's sensitivity? I'm not qualified to give you instructions for that, but it is written up in the Kohler service manual (the last part of section 6 in the version I have). 2 1 Share this post Link to post Share on other sites
ebinmaine 77,079 #7 Posted May 18, 2020 5 hours ago, tunahead72 said: governor's sensitivity Yes. I'll check that file out later today. Thanks! 1 Share this post Link to post Share on other sites
