gwest_ca-(File Mod) 12,417 #26 Posted May 16, 2020 Sounds like that 15 amp fuse is the 25 amp fuse in the diagram. Will it start now? Garry 1 Share this post Link to post Share on other sites
Whguy46041 10 #27 Posted May 16, 2020 49 minutes ago, gwest_ca said: Sounds like that 15 amp fuse is the 25 amp fuse in the diagram. Will it start now? Garry No sir still nothing. Think I’m just going to bite the bullet it and get it to a shop. This has given me a headache for sure 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,417 #28 Posted May 16, 2020 When you turn the key to start does the tan wire get power? Garry Share this post Link to post Share on other sites
Whguy46041 10 #29 Posted May 16, 2020 12 minutes ago, gwest_ca said: When you turn the key to start does the tan wire get power? Garry Yes when I try and start it it gets power but still no cranking. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,417 #30 Posted May 16, 2020 Only 2 switches left. I think you can probe the back of the pto switches at the right end of the battery. If the tan wire still has power there when turned to start try the purple. It should have power when the pto is OFF. Garry 1 Share this post Link to post Share on other sites
Whguy46041 10 #31 Posted May 16, 2020 45 minutes ago, gwest_ca said: Only 2 switches left. I think you can probe the back of the pto switches at the right end of the battery. If the tan wire still has power there when turned to start try the purple. It should have power when the pto is OFF. Garry Purple has power as well when I try to start it. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,417 #32 Posted May 16, 2020 You have narrowed it down to the last switch which is down inside the tunnel the shifters come out of. If you can remove the wires from the relay or check the light blue wire going to the relay it should also have power with the key in the start position. If not the problem is at the clutch pedal switch. Maybe get a light down there and see if the switch still looks like it is mounted in the side panel. Garry 1 Share this post Link to post Share on other sites
953 nut 68,162 #33 Posted May 16, 2020 2 hours ago, Whguy46041 said: Yes when I try and start it it gets power but still no cranking. Are you sitting in the seat whit your foot pushing down on the clutch at this point? I know how easy it is to overlook something like this while troubleshooting. Share this post Link to post Share on other sites
Whguy46041 10 #34 Posted May 16, 2020 1 hour ago, gwest_ca said: You have narrowed it down to the last switch which is down inside the tunnel the shifters come out of. If you can remove the wires from the relay or check the light blue wire going to the relay it should also have power with the key in the start position. If not the problem is at the clutch pedal switch. Maybe get a light down there and see if the switch still looks like it is mounted in the side panel. Garry Got it fixed and running. It was the pto switch. So I put a jumper in it and wrapped it up with tape. Thanks for all your guys help. Very much appreciated. 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,417 #36 Posted May 16, 2020 Those switches are not expensive and still available from any Toro dealer https://www.partstree.com/parts/toro-111332/ Good work. Garry 1 1 Share this post Link to post Share on other sites
Rob R 989 #38 Posted May 17, 2020 (edited) On 5/16/2020 at 7:34 AM, Whguy46041 said: I followed the pulley but didn’t stee a ball bearing. I'll try to send you a pic tomorrow. It is hard to see the ball bearing hits the pulley shaft when the clutch is depressed, if the arm is a little out of alignment it will not hit the ball with switch behind it and close the circuit. Take the belt cover off and you will find it..... Edited May 17, 2020 by Rob R Share this post Link to post Share on other sites
Rob R 989 #39 Posted May 18, 2020 On 5/16/2020 at 7:34 AM, Whguy46041 said: I followed the pulley but didn’t see a ball bearing. Take the belt cover off and follow swing of the belt engaging idler pulley the arm of that pulley rubs against the switch (when the pedal is depressed) and this closes thee circuit. Share this post Link to post Share on other sites
