Ed Fox
Noise from flywheel area
Ed Fox
Hello. I have a 312-8 with a 12hp Kohler. I have a rattling noise coming from the screen/flywheel area. I bought the tractor two years ago and it existed then, last year I had an issue that some of you helped me through which required me removing the shroud and screen from the fly wheel. When I had it off nothing was loose, I reassembled it and the noise is still there. Just sounds as if the screen covering the flywheel is loose but it isnt. Any ideas?  Just short of 700hrs on it.
Thanks
Ed
moe1965
Only thing I can think of is maybe your starter wheel is not fully retracting after you start the engine
Ed Fox
Thanks Moe, I'm going to pull the shroud and screen again and run it with out. See if can pin point it. I'll post back.
moe1965
Don't run it too long without that  shroud on it you'll cook your engine
