Tcorr89 6 #1 Posted May 8, 2020 Took my starter off of my c-160. Bench tested it no good. The starter that was on is not original and has 13 teeth. Everything I look up for replacement shows ten teeth. Should that be any issue? Any and all help is greatly appreciated 1 Share this post Link to post Share on other sites
Achto 32,795 #2 Posted May 8, 2020 (edited) 11 hours ago, Tcorr89 said: Took my starter off of my c-160. Bench tested it no good. The starter that was on is not original and has 13 teeth. Everything I look up for replacement shows ten teeth. Should that be any issue? Any and all help is greatly appreciated If the starter worked before with out grinding, then I would say that the starter was correct. Here is one source for a new starter, http://www.psep.biz/store/kohler_starter_motors.htm Edited May 8, 2020 by Achto 1 Share this post Link to post Share on other sites
chip61 666 #3 Posted May 20, 2020 Here ya go-I knew I had seen this before! 1 Share this post Link to post Share on other sites
