Olratlr 25 #1 Posted May 4, 2009 Well I picked up a D180 Friday runs like a scalded Dog I got a Snow plow, Plow and Harrow with it but It has a lot of play in the steering haven't got the manual in yet any help on steering is appreciated. :omg: Share this post Link to post Share on other sites
Olratlr 25 #2 Posted May 4, 2009 I forgot it has a Three point Hitch and Ag Tires. Share this post Link to post Share on other sites
rickv1957 77 #3 Posted May 5, 2009 steering play can be tightend removing cotter pin from the very bottom of column and tightening adjustment as it is threaded taking out most of free play also grease fitting on box,Rick Share this post Link to post Share on other sites
d180man 5 #4 Posted May 5, 2009 Hi nice and just like rick sead but if you still need some help fill free to email i have a dealer book on how to work on them ! :omg: Share this post Link to post Share on other sites
Eriks Red horse herd 122 #5 Posted May 5, 2009 Thats true what Rick V said, There is also on the side of the gear box a sloted screw with a nut around it. unloosen the nut and try to adjust the slotted screw to the right. That is the adustment for the worm gear and the pin gets worn with flats after awhile. I took mine out and had a friend regrind the bullet shaped stud (mine was worn pretty bad). That helped alot. Also makesure your tierods and drag link aren't loose or sloppy and check your bell crank the ( the tierods & draglink is attached to under the tractor) make sure the stud isn't loose or worn in the threaded hole. You might have to put a nut on top of the bolt to take up slop. Share this post Link to post Share on other sites
d180man 5 #6 Posted May 10, 2009 Hi there is what is in one of my books hope this helps! if you still need help just let me know! Share this post Link to post Share on other sites
Confused99 2 #7 Posted May 10, 2009 Thank you very much D180MAN!!! I need to adjust the steering on my new one too. Share this post Link to post Share on other sites
rickv1957 77 #8 Posted May 10, 2009 Hey D180 man,give me a call today if you get a chance,Rick Share this post Link to post Share on other sites
d180man 5 #9 Posted May 10, 2009 Hi hope it can help you work on them! and nice talking rick! take it ezy :omg: Share this post Link to post Share on other sites
