canam1991 2 #1 Posted May 4, 2009 I have a 250 and it turns great from straight to the left its nice and easy but from the center to the right it acts like something is binding what could be a cause? :omg: Share this post Link to post Share on other sites
clintonnut 126 #2 Posted May 4, 2009 Hi Mine has a little knot steering right too. I think the steering box has too much end play. Charlie Share this post Link to post Share on other sites
canam1991 2 #3 Posted May 4, 2009 Yah but it acts like if i force it it will break something? could you change the fluid or split the case and see whats happening on the inside? Share this post Link to post Share on other sites
canam1991 2 #4 Posted May 5, 2009 I just took it for a spin and it was fine it acted like it good hot and started to seize up:( could it maybe be low lude? how do you check it? Share this post Link to post Share on other sites
clintonnut 126 #5 Posted May 5, 2009 Theres a plug on the top of the steering box. I think you have to take the dash off to access it. It might be easier to remove the four bolts holding it in underneath and drop the steering box down to check the fluid. I think it requires 10w 30? Share this post Link to post Share on other sites
canam1991 2 #6 Posted May 5, 2009 Today i was going to check the fluid but i noticed the cap laying on top broke of.... Does anyone have a pic of the steering case so i can make sure thats it? Thanks Share this post Link to post Share on other sites
oilcrazy 0 #7 Posted May 5, 2009 The steering box plug is a plastic plug on the top front of the box, you can see it if you look between the battery and glass overflow bottle. Use 80/90 gear lube and if it leaks (most of them do), put a grease fitting in place of the plug and pump it full of soft grease. also Ray's Mower Shop in Boyertown Pa has a front blade for sale. He has an ebay store where you can see it. Hope this helps. Share this post Link to post Share on other sites
canam1991 2 #8 Posted May 6, 2009 Where is the drain plug on the bottom? is it the three bolt plate? Share this post Link to post Share on other sites
rogerwhosoever 0 #9 Posted July 13, 2012 I am looking for a steering wheel gear box for the D- 250 Wheel Horse Lawn tractor. The gear box has two thrust bearings , one located at the bottom of the steering shaft and the other at the top. Water leaks down into the gear box from around the cap over the nut on steering wheel, causing the bearings to rust ( cheap bearings from Italy) The rusted bearing cause the steering wheel to jam and the bearings have to be replaced. Finding them is near impossible. They are metric I think and will have to take the steering shaft to a bearing dealer to find them. If any one knows a source for them let me know 1 803 840 7860 Share this post Link to post Share on other sites
