Axel 0 #1 Posted May 2, 2020 Hi everyone, I am having a meltdown trying to figure out this no crank on my 1999 Toro Wheel horse 314-8 . A little background, This started as an intermittent no crank with the key and if I kept cycling the key it would eventually make a connection and start. One other note is when it was running if I tried to set the E-brake (in neutral) it would kill the engine. Now it will not crank but I am getting the start signal to the relay on the orange wire but it doesn't exit to the solenoid. I have replaced the solenoid, checked all relays,fuses and switches and the wiring is intact with good grounds. There are two relays under the shift panel and when I remove the one on the right (when looking down- See picture below) the tractor starts and runs (as long as the brake is not engaged) but without the relay in I have no reverse mowing and if I set the brake the engine will die. I believe the problem lies in the reverse module? Any help would be much appreciated! Thanks in advance. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #2 Posted May 2, 2020 Welcome to the forum. Have you seen these detailed wiring diagrams? Each circuit has it's own diagram. There may be more you could use. Let us know how you make out. Garry Share this post Link to post Share on other sites
