CoolvilleMafia 0 #1 Posted May 2, 2020 I have a 48" mower deck that I am looking for good spindles or possibly complete mower deck parts mule that will work on my 96' 520H. My deck is still solid. Any info on alternate fitting decks appreciated also. Thanks! Share this post Link to post Share on other sites
lynnmor 8,644 #2 Posted May 2, 2020 You have a choice of a 42" rear discharge, a 42" rear discharge Recycler, a 48" side discharge and the very large and heavy 60" side discharge. If you have a very large lawn, the 60" will reduce mowing time considerably. Here is a 1995 brochure that is the same as 1996. Share this post Link to post Share on other sites
oliver2-44 11,272 #3 Posted May 2, 2020 @CoolvilleMafia You should post you parts request in the Classified Wanted Section. You might also check the Vendors Section and see if A-Z tractor or one of the other Vendors has the parts you need. You Share this post Link to post Share on other sites
Lee1977 7,572 #4 Posted May 2, 2020 6 hours ago, lynnmor said: You have a choice of a 42" rear discharge, a 42" rear discharge Recycler, a 48" side discharge and the very large and heavy 60" side discharge. If you have a very large lawn, the 60" will reduce mowing time considerably. Here is a 1995 brochure that is the same as 1996. 42" decks don't work with a 520 the deck wheels hit the rear tires. Mine a 1989 with 7" rear wheels and right deck wheel rubs the tire. If he has 8.5" rear wheels there is no way it will work. I changed mine out to a 48" deck. Share this post Link to post Share on other sites
lynnmor 8,644 #5 Posted May 2, 2020 1 hour ago, Lee1977 said: 42" decks don't work with a 520 the deck wheels hit the rear tires. Mine a 1989 with 7" rear wheels and right deck wheel rubs the tire. If he has 8.5" rear wheels there is no way it will work. I changed mine out to a 48" deck. That’s funny, I bought a 42” deck with a new 520H way back in 1991. Note that only the rear discharge is compatible. Also see the brochure I linked to. Share this post Link to post Share on other sites
daveoman1966 3,882 #6 Posted May 2, 2020 (edited) 11 hours ago, CoolvilleMafia said: I have a 48" mower deck that I am looking for good spindles or possibly complete mower deck parts mule that will work on my 96' 520H. My deck is still solid. Any info on alternate fitting decks appreciated also. Thanks! Do the spindle PULLEYS on your 48" deck use a WOODRUFF KEY or not? If the shaft is 3/4" diameter...YES. If the spindle shaft is only 5/8" dia, then yours do NOT use the keyway. I ahve two GOOD USED spindles...for 42 or 48" decks..these DO HAVE the keyway slot. I do not have the pulleys though. Edited May 2, 2020 by daveoman1966 Share this post Link to post Share on other sites
