Cape Codder 5 #1 Posted May 1, 2020 Do all 37" SD decks use a flat and V pulley ? I ordered the parts and spacers and it's working, but I believe I have the 6 sided belt. Could someone explain to me the correct configuration with pulleys and spacers. Can I do any harm running it with the flat pulley ? It is a late model Toro Wheelhorse Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,861 #2 Posted May 1, 2020 The first model 05-37SC01 used the 6-sided belt. Second model 05-37SC02 started using a regular 4-sided belt. Garry Share this post Link to post Share on other sites
Cape Codder 5 #3 Posted May 2, 2020 Thank you, I believe I have the SC-01 with the 6 sided belt and 2 v pulleys. I 'll replace the flat outer pulley with the correct one. 1 Share this post Link to post Share on other sites
clueless 3,334 #4 Posted May 2, 2020 Anyone if what the difference is between the older SC-01 and the SC-02 besides the mule drive pulleys? I have the older one with the sixes sided belt, during the year I swap the 37", and my 42"rd out a couple of times. I would like to just keep the V/ flat pulley mule drive on all the time. What would I need to change on my deck? Share this post Link to post Share on other sites
dcrage 631 #5 Posted May 2, 2020 I think all you would need to do is put two flat idler pulleys on your 37” deck. I assume you have v shape idlers at the front with the six sided belt. Share this post Link to post Share on other sites
