truckin88 104 #1 Posted May 4, 2009 Ok I downloaded all the manuals (they do not have a clear answer), the hydro works fine, but the fluid is probably the original from 91, do you think it should be left or changed??? It states the system requires little maintainence. Also how do you drain it, and what and how much do you fill it up with. Thanks guys!! Share this post Link to post Share on other sites
Docwheelhorse 2,740 #2 Posted May 4, 2009 HI---I do not know if your system (or the 200's in general) allow for a fluid change. Many systems say "serviced for life of transaxle"---Craftsman's version, or similar and you simply cannot change the oil, a completly stupid idea but true nontheless! Tony Share this post Link to post Share on other sites
