truckin88 104 #1 Posted May 4, 2009 Want to change the fluid on my C-120 8spd. How much fluid, I read varying numbers, the most consistant looks to be 2qts, and what type 75-90 or 85-140?? Do I just drain at the allen plug? Thanks and tips are useful! Share this post Link to post Share on other sites
dodge78 94 #2 Posted May 4, 2009 I just did mine saturday. It took 2 quarts and I used 85-140 TYPE 5. Remove the plug on the bottom with an allen wrench. I used a 1/2" copper pipe in the dipstick hole with a large funnel wedged in to it and taped it so it would not fall off. Funnel to pipe that is. Here is a picture of my old fluid but it sat outside for a year or two with practically no shift boot on it. Share this post Link to post Share on other sites
Stigian 1,234 #3 Posted May 4, 2009 Yuk, that oil does look slightly past it's best Quite a nice pattern it has made in the bucket though... Yes I know... Im a bit strange :omg: Share this post Link to post Share on other sites
lotus1967 0 #4 Posted May 4, 2009 Would this be the same rear end one would find on a 418? I.ve always used 90 wt. Share this post Link to post Share on other sites
gwgdog66 23 #5 Posted May 4, 2009 Would this be the same rear end one would find on a 418? I.ve always used 90 wt. Yes, I downloaded a lube chart from one of the sites in the links section, and the 418-8 shows this: T-3..SAE 90-140 A.P.I. Service GL-5 Gear Lubricant (No Service Interval) I changed mine (C-160 8) weekend before last and it came out much like in the picture shown above. I went with royal purple 90-140 GL5. Share this post Link to post Share on other sites
Astrolite 1 #6 Posted May 6, 2009 Ok, back to the question on how much oil. I just changed the oil in my "75" C-100 and the dipstick shows it slightly over full at 1 1/2 qts. The service manual says 2 qts. Which is right? Has anyone else noticed this? My trans model is 5091. Share this post Link to post Share on other sites
gwgdog66 23 #7 Posted May 6, 2009 Mine did too. The first quart I filled from the fill hole right behind the brake band. It wouldn't take anymore there. I checked it, and it was barely on the stick. The second 1/2 quart I had to fill through the dipstick tube. It checked slightly over filled. I ran it for a good two hours afterwards, and checked it the next day and it read low, so the unused 1/2 qt went in. No leaks anywhere, the top bottom and sides of the case were dry, no leaks on the garage floor. Now it reads full every time I check it. Maybe I created some kind of air pocket by using the dip stick tube to fill it up. Share this post Link to post Share on other sites
Astrolite 1 #8 Posted May 6, 2009 Maybe that's it. I added the oil through the dipstick hole too and really haven't used the tractor since. I'll cut the grass as soon as it stops raining and check it again. Thanks! Share this post Link to post Share on other sites
