bilyt680@gmail.com 0 #1 Posted April 27, 2020 Can anyone tell me what size belt i need for my 1056 that goes from pto to mow deack Share this post Link to post Share on other sites
daveoman1966 3,884 #2 Posted April 27, 2020 (edited) depends onn your mower deck size... 36 42 or 48. Look it up and buy the belt here...usually under $20 bux for the OEM belt. Note... Find OEM belts here..(the aftermarket belts don't usually match well to these older Wheelhorse products.) https://www.psep1.biz/arinet.asp?aribrand=TO# Find your mower deck model at the Toro Master Parts viewer. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Enter you model # as 1056.. then select Accessories... then pick you Mower Deck Size.... follw thru the schematics of that deck. Not tuff to do, but takes a little patience.. Looks loke PTO belt for 36" is # 1563 (NLA). 42" is 6737 (9782) and 48" is 6771 (9783) I suggest you VERIFY those PTO belt ID numbers.... to be sure as there are any number of 36, 42, or 48" decks that would fit your maching...and the PTO drive apparatus MAY have been upgraded. Best to get you DECK ID NUMBER identified to be CERTAIN. Edited April 27, 2020 by daveoman1966 Share this post Link to post Share on other sites
bottjernat1 2,196 #3 Posted April 27, 2020 Welcome Try going threw the manual section on here should be able to find the deck you have then the belt size you need. Share this post Link to post Share on other sites
