jerry potaracke 3 #1 Posted April 27, 2020 does anybody know if the 142-0661a carburetor from asap performance will work on a b43m gao16 onan engine i have a wheel horse d160 with fuel issues thanks Share this post Link to post Share on other sites
lynnmor 8,557 #2 Posted April 27, 2020 A link to the company and the part might help. Share this post Link to post Share on other sites
pacer 3,179 #3 Posted April 27, 2020 Is this the carb you're talking about - it shows 0660 but no 0661 ---- However, this should be what would go on the B43 series. (I have a B43 and that is the carb) But do you really want to spend $440 for one???? There are rebuild kits out there and that carb is just plain simple to rebuild. If it has had this wonderful ethanol fuel been running thru it then it no doubt needs a rebuild! What are your probs with it? - surging/pulsating is typical, or something else? Onans are rather notorious in being finicky tuning. I chased a problem on mine til I was at the point of getting another engine but I decided to - ONE MORE - time going through all the cks, ignition, wiring, carb (which I had rebuilt 2-3 times!)etc and sure enough when I pulled the points/condenser and was looking them over - once AGAIN! - I notice a tiny crack in the insulation on the condenser which was VERY close to the case. When I kinda bent the wire it was very brittle and cracked open badly -- so I replaced it and voila!! problem solved!! Hours and hours messing with it and all along it was a faulty condenser! Share this post Link to post Share on other sites
