3WHDave 60 #1 Posted April 27, 2020 This is a new response to an old post... I’m restoring a D180 and like many, my oil temp gauge has a broken needle. The plastic was not UV stable and deteriorated to the point of near-powder. I see many posts on oil pressure, but not on temp gauges. I did disassemble the old gauge and it appears to be fine (removing bezel is a pain, slow going expanding crimp). Is there an OEM, or near OEM source? Again, all suggestions are appreciated. PS: engine reasonably going well, may fire it up with temp gas tank, mine is out for paint sand blasting. Last resort: 3D print a needle. Share this post Link to post Share on other sites
WHX?? 58,324 #2 Posted April 27, 2020 Check with A-Z tractors https://a-ztractor.com/ he may have a good used one. Share this post Link to post Share on other sites
3WHDave 60 #3 Posted April 28, 2020 Thank you WHX24, I will do so! 1 Share this post Link to post Share on other sites
