mark in ny 27 #1 Posted April 27, 2020 So I bought a pretty rough c145 for 180 bucks with hydro lift. Everything looks and appears in tact complete and not leaking. I have 3 horses currently a complete a running and driving charger and a parts 312-8. So I was tearing down the 312 to scrap and keep any good parts when it crossed my mind why cant I restore the frame of the 312 and swap everything over it to it from the c145 as I'm looking to restore the c145. Jack's list the c145 frame as #109316 , the 312 as 110648. Toro lists the 312 as 782680. Parts tree says the c145 is superceded to the 782680. Can anyone confirm if they are in fact the same frame? Thanks Share this post Link to post Share on other sites
Sparky-(Admin) 24,035 #2 Posted April 27, 2020 My gut says the frames are the same. The diff part numbers might refer to the mounting holes, maybe . The C145 has the Kohler K on the shaker plate while the 312 has mounting holes for either a direct mount Kohler K or Magnum. 1 Share this post Link to post Share on other sites
953 nut 63,152 #3 Posted April 27, 2020 I don't own a "C: series but the front portion of the front axle mount on the 312 may be the only thing that changed. On the 312 the Mule drive mount and axle mount are a one piece unit, I think on the "C" the two tabs for the axle pivot pin were welded to the frame. No big deal. Share this post Link to post Share on other sites
ebinmaine 75,881 #4 Posted April 27, 2020 29 minutes ago, 953 nut said: on the "C" the two tabs for the axle pivot pin were welded to the frame. No big deal I don't have any later model ones to compare to. I have frames as new as 1977 or 78. Those have the rear tab mounted to the frame but the front attachment point for the axle is part of the attach a matic plate. It bolts to the front of the frame. As long as the length of each frame is the same I don't know why it wouldn't work. 1 Share this post Link to post Share on other sites
953 nut 63,152 #5 Posted April 27, 2020 2 minutes ago, ebinmaine said: the rear tab mounted to the frame but the front attachment point for the axle is part of the attach a matic plate. It bolts to the front of the frame. Thanks Eric, I was unsure about the year this changed. 1 Share this post Link to post Share on other sites
Lee1977 7,462 #6 Posted April 27, 2020 10 hours ago, mark in ny said: So I bought a pretty rough c145 for 180 bucks with hydro lift. Everything looks and appears in tact complete and not leaking. I have 3 horses currently a complete a running and driving charger and a parts 312-8. So I was tearing down the 312 to scrap and keep any good parts when it crossed my mind why cant I restore the frame of the 312 and swap everything over it to it from the c145 as I'm looking to restore the c145. Jack's list the c145 frame as #109316 , the 312 as 110648. Toro lists the 312 as 782680. Parts tree says the c145 is superceded to the 782680. Can anyone confirm if they are in fact the same frame? Thanks If both frames have two 3/4" bars supporting the foot pads I would say they are the same. The early C-series 1976 and 1977 had just one at the fronf of the foot pad but they did't have the gas tank under the rear fender. Share this post Link to post Share on other sites
Goldnboy 1,067 #7 Posted April 27, 2020 The frame from my 1984 GT1848 has holes for a direct bolt wide base Kohler too. I just mounted a Kohler on this weekend didn't need to use J-bolts. Share this post Link to post Share on other sites
mark in ny 27 #8 Posted April 27, 2020 1 hour ago, Lee1977 said: If both frames have two 3/4" bars supporting the foot pads I would say they are the same. The early C-series 1976 and 1977 had just one at the fronf of the foot pad but they did't have the gas tank under the rear fender. Both do have the gas tanks under the seat as well as the bars. As far as engine mounting being different the c145s shaker bushings are shot so it's going to get a direct bolt pan as I have one laying around. My only concerns are the mounting for the rear end would be the major factor. The 312 has all the steering and attachments. So really the dash and rear end are the only iffy things Share this post Link to post Share on other sites
Lee1977 7,462 #9 Posted April 27, 2020 1 hour ago, mark in ny said: Both do have the gas tanks under the seat as well as the bars. As far as engine mounting being different the c145s shaker bushings are shot so it's going to get a direct bolt pan as I have one laying around. My only concerns are the mounting for the rear end would be the major factor. The 312 has all the steering and attachments. So really the dash and rear end are the only iffy things The dash tower is the same except for the top section the switch and gauges might be some different. . The frame to transmission is the same bolt pattern. They went to bolt down fender pans in 1976 and a the later fender pans C's .300. 400 and 500 the hole to bolt them down are the same. 1 1 Share this post Link to post Share on other sites
